Old 09-23-2010, 03:40 PM   #1
1964 24' Tradewind
Pagosa Springs , Colorado
Dometic RM66F Not Cooling
Hi,
This is my first post. I just bought a 1964 24' Tradewind and had it moved home last week.
I am currently checking out the mechanical systems. The refrigerator was not working, so after picking the locks on the access doors (no keys), I discovered that it was not plugged in. I plugged it into a heavy duty extension cord from the house but the unit didn't heat up (bad 120V heater element). The trailer is not wired for 12V operation of the refrigerator, so I ran wiring directly from the converter to the unit and the tubing is now warm/hot to the touch, but still no cooling. I have read here that these refrigerators may become vapor locked and that turning them upside down and righting them again may cure this condition. Has anyone had any luck in doing this? The unit is level. Is there anything else that I should check/do before concluding that the cooling unit is bad?
Jim1964TW is offline   Reply With Quote
Old 09-23-2010, 05:35 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Where did you connect the 12v wiring to the refer? As far as I know it only works on 120 volt and propane. When you say it gets warm/hot. Where? It takes a long time 24 hours to cool the refer in electric mode. Can you operate it on propane? If so it will cool somewhat faster but it still takes 16 to24 hours to bring the temp down, especially in a warm environment. I have an RM66 refer, it does not have a 12volt system.
Check out my previous post, there are a number of them that I've posted after working on mine and getting it to function both on propane and electric. I have attached a photo of the controls on my unit. I'm not sure yours is like this.
TG Twinkie is online now   Reply With Quote
Old 09-24-2010, 01:50 AM   #3
1964 24' Tradewind
My RM66 does have a 12 volt option on the second knob from the right. The reefer is not OE. It was purchased in 1979. That is why the trailer was not wired for 12v. Perhaps that is what the "F" suffix on the model number designates. Anyway, the reefer has started cooling (YAY!). I had not replaced the access doors because the only thing that holds them on is the lock. I have no keys and I didn't want to have to pick the locks again. I removed the locks, duct taped the doors in place and cleaned the bottom vent. After that the reefer started cooling fairly rapidly. I have ordered a 120V heater element replacement. I haven't done anything with the propane yet.
Dometic RM-100 Cooling Problem startrekker2001 Refrigerators 9 11-19-2009 07:30 AM
Changing the cooling unit in my Dometic RM3604 Trailertroll Refrigerators 2 08-17-2009 03:08 PM
Dometic cooling fan noise dlb435 Refrigerators 10 06-24-2009 07:48 AM
AC Not cooling acrane Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-09-2006 12:43 AM
A/C Not Cooling Cracker Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-23-2005 08:16 PM
