Old 02-06-2012, 07:50 PM   #1
Dometic RM3807 Refrig Diode problem?
I have a 95 34' AS and have been told a faulty Diode is behind the refrig gas operation problem. The refrig has worked great for 10 years but always electric. There is gas and the refrig "tries" to light for a few minutes and then goes to 'check' mode. I have a good set of manuals and they don't even show a 'diode'. The repair shop said they have looked at several sources and couldn't locate a replacement diode. I see electrode but no diode
Does anyone have experience with this problem or a source of a replacement diode and possibly what the 1995 name is for same.
Thanks/l
lmcatee is offline   Reply With Quote
Old 02-07-2012, 07:52 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
If any of the electronics are failing, the usual approach is to replace the entire circuit board assembly. Usually people use the aftermarket replacements from Dinosaur Electronics, which are said to work better and are cheaper.
MICRO P-711 page
They cost around $100.
Dometic Refrig no lights on panel texascanuk Refrigerators 6 01-30-2014 06:51 PM
Potential Problem? Pictures included palmtreegirl 1990 - 1993 Excella 51 08-12-2013 10:50 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
2010 Dometic A/C hansenk Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-04-2011 08:33 PM
Thanks to the forum for Dometic recall info Kosm1o Refrigerators 1 06-17-2011 05:41 AM
