Old 05-26-2015, 09:10 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Dometic RM3762 fridge light
Interior light burnt out. Looks like it got hot.
Checked voltage to light - 13.6 VDC with door open.
Door closed - 8 VDC!
Voltage to interior light when door is closed!?? Called Dometic and for this model yes, the light comes on from time to time when it's closed to heat it up and cause the system/refrigerant to cycle.
I had put a LED light in it yesterday as a short term fix. BAD IDEA! You need the 10 watt incandescent for the system to work. It's a light and a heater!
So if the light dies replace it ASAP and with the spec bulb. No Led on this model!
Also do not cover the light with the broccoli!
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
1000w inverter for Dometic Rm3762 GammaDog Electrical - Systems, Generators, Batteries & Solar 16 11-14-2014 09:18 AM
Needing Check Light Sensor for RM100 Dometic Fridge Auretrvr General Repair Forum 0 06-06-2013 07:39 AM
Dometic RM3762 Error code E1 help Airstream01 Refrigerators 18 05-16-2013 08:43 AM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
Dometic RM3762 turns off oceanair Refrigerators 9 06-08-2009 11:37 PM
