Old 01-11-2016, 08:48 PM   #1
1988 29' Excella
Prescott , Arizona
Dometic RM2820 won't turn on
Hello,
My airstream was under construction for a few years so the fridge sat un-used during that time period. It worked fine before I began renovations but now it doesn't seem to want to turn on. We checked the 110 and it is getting power from the outlet to the lower components but when I press the "on" button on the upper control face nothing happens. Thank you for your help with this. I began full timing today so getting this fixed is somewhat of a priority.
Tim
SleeperAS is offline   Reply With Quote
Old 01-11-2016, 09:18 PM   #2
1986 31' Sovereign
Miami , Florida
I hate to even ask the obvious but have you checked that you are getting 12vdc to the board?
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 01-12-2016, 07:21 PM   #3
1988 29' Excella
Prescott , Arizona
I had an epiphany. When I was renovating it, the 12v line for the fridge was on a different fuse block than the distribution panel said it should be on. I put it back on its original, which is apparently no good.
To answer your question, I did not check the 12v, my GFs dad is an electrician and was back there checking and all he mentioned was the 110v. Either way it is back to its former glory.
Tim
Replacing a Dometic RM3804 fridge with RM2820 ... any advice? skydiva Refrigerators 10 05-04-2017 07:24 PM
Dometic Classic RM2820 Ben4762 Refrigerators 2 07-02-2013 03:18 PM
Dometic Refrigerator Door Handle RM2820 texascanuk Refrigerators 1 07-22-2012 03:46 PM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Getting a New RM2820 NashBuff Refrigerators 12 06-24-2010 03:44 PM
