Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 07-07-2010, 08:25 PM   #1
Alliesargosy's Avatar
1978 Argosy 27
Bay Area , California
Dometic RM2812 - is it dead?
So we've got a Dometic model RM-2812, in decent shape it appears. We are on 30A shore power, everything else works but the fridge. There is 120 at the board on the back of the unit, but the lights don't come on, no cooling, nada. I do not have a manual (but I do have the parts list), but it seems like a very simple fridge. Am I missing something? Does it need to be exactly level? I've followed the instructions on the interior label, but have not tried it on gas. The fuses were good.
Alliesargosy is offline   Reply With Quote
Old 07-07-2010, 08:30 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
This could be as simple as a blown fuse (12 volt) or maybe a bad circuit board. This link should help in troubleshooting the problem:
http://www.rvrepairnow.com/library/S...o%20RM2852.pdf
Richard
azflycaster is online now   Reply With Quote
Old 07-08-2010, 09:36 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
Yes, be sure it's getting 12 volts. The controls require it even when running on 120 volts.
Old 07-08-2010, 10:26 PM   #4
1978 Argosy 27
thanks, I'll check it out properly next week. Until then, it's an igloo and bags of ice, I guess.
Old 07-08-2010, 10:47 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Not if it is the original fridge.
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 07-08-2010, 11:27 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Bill
The thread title and first post make it clear that it is a Dometic RM 2812 which does have a control board.
Service Manual pdf attached. Hope it helps.
Vaughan
Old 07-17-2010, 08:42 AM   #7
1978 Argosy 27
Thank you everyone - it's working like a champ now! I checked out the 12v on the back panel, nothing. Traced it back to an inline fuse at the battery, which was blown. Working great now - thanks again!!!
Old 07-17-2010, 11:24 AM   #8
1983 34' Excella
1967 24' Tradewind
Images: 32
Great! That's the kind of fix we all hope for. Thanks for the update.
Vaughan
Dead Dometic Fairleigh Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-10-2009 12:10 PM
Well, its DEAD! SilverToy Tow Vehicles 34 06-30-2007 12:56 AM
Dometic RM 75 dead - can't be repaired Alumin8 Refrigerators 24 09-03-2006 12:56 PM
Dometic 12V drain (RM2812) bhayden Refrigerators 4 07-18-2006 10:53 PM
Looking for someone with a dead Dometic RM-100 87MH Refrigerators 2 06-30-2005 07:06 PM
