Old 01-10-2010, 01:29 PM   #1
2007 28' International CCD
Vail , Arizona
Dometic RM2662 door latch
The door latches on my RM2662 do not hold the doors closed on the road and if not tied the contents wind up on the floor. Is there a ready made solution? If not, I have been thinking of fabricating a positive latch using a hinge on the opposite side, between freezer and refrigerator door, with a removeable pin and plate. We used to do this when I was building yachts, and it should work here, using the ready made hinge mounting points that are currently capped. Anyone else have the same problem, know of an easy solution?
blaisew is offline   Reply With Quote
Old 01-10-2010, 01:36 PM   #2
Lothlorian's Avatar
Loganville , Georgia
I have the same problem, but I have gone with a temporary fix. I use a aluminum tie that holds chain link fences to posts. It is sturdy but very pliable. I just wedge the aluminum tie between the latch and the door when traveling on the road and the doors don't open.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Where can I find a replacement latch for Dometic wacnstac Refrigerators 12 02-20-2014 01:03 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
67 outside door latch CJ of Okla 1967 Overlander 4 04-29-2009 05:58 AM
Dometic door latch ? fossil Refrigerators 2 06-26-2008 09:39 AM
Dometic 2800 door latch spring artnsue Refrigerators 1 04-24-2007 04:54 AM
