08-12-2008, 12:03 AM
#21
2005 25' International CCD
1960 18' "Footer"
Riverside
Originally Posted by flyfshr
Thanks for the info Garry. Do you have any contact info for the company you got yours from? I doubt its the same one for the RM2607 but maybe.
FF
Brad, Best Converter sells them, check the following link.
Dinosaur Electronics
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
08-12-2008, 07:46 AM
#22
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Already ordered one. Should be here Friday so I have some unrelated work to do while the fridge is out like I would love to add an aluminum vented panel to allow the fridge to breathe better. I know where is one, just gotta get the guy to all me back. Of course, it will need polishing before installing.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
08-20-2008, 10:44 AM
#23
The fridge worked great on our trip up North last weekend. I did get a few "check" lights but only while traveling and frankly, I don't understand how that thing is supposed to stay lit while traveling down the road at 70 mpg.
While parked, it had no problems whatsoever.
fyi.
jb
NFL Owner
08-20-2008, 11:25 AM
#24
Naples
Alternate test re: Check light
OK guys,
You've been doing good tracking down your check light problems, especially those related to the board. HOWEVER..........there are other problems which might be causing your check light to go on.
Specifically, those that deal with ripple or 'dirty' DC current reaching the fridge. This type of 'bad DC' will wreak havoc with your PC board AND cause the recurring check light problem!
The easiest way to test for this is to connect a separate 12VDC source (like another battery) directly to the 12VDC input at the back of the fridge. If you still have the check light problem when connected to a dedicated, independent 12VDC source, then it is most definitely your board. If the fridge then runs properly with no check light......you have a DC supply problem and have to look further into your power supply (converter) battery condition and what other types of components are connected to the same feed line that the fridge is on.
Let me know if you need more info on this 'phenomenon'.
lewster
08-20-2008, 11:29 AM
#25
1959 24' Tradewind
Phoenix
Thanks jb and Lew. I ordered the new Dino board but am going to wait to install it until after our Labor Day rally. I don't experience 'check' light problems while on 110AC and the campground has full hookups. I'll install it once it cools off some around here. Still hovering around 108 degrees lately.
FF
09-13-2008, 07:26 PM
#26
TAC OH-17
1994 34' Limited
Upper Sandusky
, Ohio
hey we are having similar problems just what is a dinosaur board, is it on the back of the refer or that censor board thats on the front w/ the check light? we are new to this thanks julie
09-13-2008, 08:19 PM
#27
1959 24' Tradewind
Phoenix
Check out posts #13 and 21 for where to get a Dinosaur Board and make sure it is the right one for your model of Dometic. I have not swapped mine out yet. Honey-do's keep getting in the way.
FF
09-13-2008, 09:00 PM
#28
1984 31' Airstream310
Ajo
09-13-2008, 10:14 PM
#29
Naples
The Micro P-711 from Dinosaur is a military spec board as are all of the boards that Dinosaur makes, and it's less prone to the ripple DC sensitivities of the OEM Dometic board. I use Dino boards exclusively in all of my replacements.
Another thing you might want to check is the amount of AC current passing thru the rectifiers and riding along on your 12VDC feed into the refer's control board. Using a digital VOM, set it on the AC scale and apply the test leads to the 12VDC feed block at the back of the refer. If you get a noticeable VAC reading....you have conveter problems!!!!! The new Dino board will probably eliminate your check light problems, but you should have your converter checked or in some cases .......replaced!!
lewster
09-18-2008, 09:17 PM
#30
1999 27' Safari
Kent
, Ohio
My buddies fridge is doing the exact same thing. Have you replaced the mother board? and has it corrected the problem.
04-01-2013, 08:42 AM
#31
Oy...here I am again 5 years later
Having the same problem that I had when I started this thread in 2008. It worked fine all that time but late last fall it started again and is a persistent problem now. I guess I'll get another board as I have sold the unit and buyer wants everything working.
NFL Owner
