Old 08-07-2007, 12:15 AM   #1
1972 25' Tradewind
Petaluma , California
Dometic RM2510.2 not working on AC
Ah, once again I turn to the collective wisdom of airforums...
My Dometic RM2510.2 is about 4 months old and had worked fine on both propane and 120 volt AC power but the other day after being on AC about 4 days it suddenly quit working. I was able to light the LP and it started cooling but not on AC. I checked the outlet, had a solid 122 volts and all the other AC circuits are fine (TV, microwave, A/C, water heater, charger, etc.). I disconnected the AC heating element leads from the block and measured 74.5 ohms (I think the manual says within 10% of 75 ohms). I then switched the knob to electric, cranked the thermostat to max, and checked for voltage at the block--nothing!
This more or less leaves the problem as being the thermostat or the switch.
Do any of you have any experience with this and what was the problem and/or solution. I'm presently on a trip and not too excited about pulling the fridge but maybe I'll need to do it :-(. In the mean time I'm burning LP to keep things cool.
Anyone have any experiences or recommendations they care to share?
Aron
asmetana@kar is offline   Reply With Quote
Old 08-07-2007, 04:24 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
if it ohmed out ok i'd look at the switch.
john
you call them ferrets, i call them weasels.
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
