Old 03-29-2009, 02:44 PM   #1
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Dometic RM2501 constantly runs the igniter? blows fuse...
My '74 Overlander has a Dometic RM2501 2-way fridge (bought in 1987 as best I can gather from docs from the PO). Works fine on 120VAC.
Trying to make a really long story just long...the original RM77 fridge didn't need 12VDC for anything, so there was no circuit there. When the RM2501 (2way, not 3way) was installed, the 12VDC supply was obtained by tapping into the 12VDC that exists on the wall next to the fridge which is for the TV antenna amp. and std. round 12VDC outlet. I was trying to verify gas operation (mind you I've owned this trailer for about 5 weeks now) and couldn't get squat. Some helpful local airforums members traced this to the lack of 12VDC supply to hit the igniter (the 2501 has an electric igniter and automatic re-light). OK, great. Problem #1 solved. However, now the igniter is snapping, no flame. Turned out the nozzle was clogged. Problem #2 solved. So I go into the AS, turn the fridge knob to gas and even before I touch the button to "light" the fridge, it's sparking away. The instructions say to hold the button until the light on the panel goes off. Well, it never goes of, it just blinks with each spark. Good news is that the fridge did indeed light and had a nice blue flame. However, it just perpetually sparks, even when lit. I thought maybe this is the auto re-light feature??? Well, after letting it run for about 15 minutes, I was closing panels on the outside and I noticed the snapping stopped...and so had the flame. Fridge to temp? Nope...12VDC circuit blown at the fuse panel. I guess I know now why the PO had the 12VDC to the fridge disconnected in the first place. But, the question is: should this fridge be constantly sparking? If not, does this indicate a stuck igniter switch? Is it a bad thermocouple? Although you'd think if that were the case that it wouldn't light at all since the t-couple would force the stop of the gas flow. If the igniter constantly popping is the right thing to be happening then do I just need to wire it dedicated to the battery w/ its own 20A fuse? The owners manual states that the 2501 should have a dedicated 12VDC circuit w/ 20A fuse, but it does not differentiate between the 2way and 3way models and my assumption was that only the 3way would need a dedicated 12VDC line.
Please help! We're hoping to hit the road on Wed. for CBR and we'd like the fridge to work since there's limited elec. available.
WineStream is offline   Reply With Quote
Old 03-29-2009, 03:15 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The spark should go off as soon as the flame is lite. The flame grounds out the spark and will not let the igniter recharge to the point of discharge. If you are getting a spark after the flame it sound like the spark is grounding to something other than the burner. Try turning the gas off and lighting the ref. while watching the spark to see just where it is ground to.
As for the fuse blowing. Is there any chance the 12 volts was hooked up with reverse polarity? This would not effect the igniter but would effect the control board operation.
What size fuse and what else is on that fuse besides the TV amp.
2004 Excursion 4x4
Old 03-29-2009, 03:21 PM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Some hack installed it; we switched over years ago and have had problem zero.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 03-29-2009, 03:24 PM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jason and Andrea,
Sometimes the igniter in our '87 is a little cantankerous, but it is the opposite of yours. We get no spark. What usually rectifies the situation is to disconnect the slip connectors and sand the connectors a little to get fresh metal.
You are correct though, once the refrigerator flame is lit is should stop sparking. Try refreshing ALL the slip connector connections and see what happens.
As an interim fix, you might be able to disconnect the piezo electric igniter and light it by hand. If the refrigerator goes out the lack of heat on the thermocouple should shut down the gas solenoid.
If you can get it lit and limp to CBR, I am sure they will descend on your refrigerator problem and have it diagnosed and fixed in no time.
Have fun at the CBR!
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 03-29-2009, 03:52 PM   #5
WineStream's Avatar
2005 30' Safari
Images: 24
maybe the weather at CBR will be more condusive to fixing a problem than it is here in northern Ohio right now! It's windy and about 43 outside. NOT the time that I enjoy standing next to the trailer trying to get the @#&^% fridge to work. Not to mention the water leaks I found when I hooked up to city water this weekend...I think we'll be at CBR with more of an aluminum tent than an RV.
Old 03-29-2009, 03:58 PM   #6
WineStream's Avatar
2005 30' Safari
Images: 24
switched over? meaning what...to a 120VAC only fridge? I've been contemplating that. We need to see how many times we do these situations like CBR where we are on little or no electricity. Then again, we're already re-planning our menu to include things that do not need refrigeration banking on the fact that this problem won't be fixed in time for CBR
Old 03-29-2009, 04:11 PM   #7
DEITZ645's Avatar
I Feel Your Pain
Jason,
Ahhh...the joys of Airstreaming
I know how you feel. I spent the first weekend of last season rebuilding the water heater in our '87 in the cold rain. New circuit board, gas solenoid valve, burner tube assembly, E.C.O, T-Stat, and igniter. My wife was sick of sitting in the bathroom and listeing to me..."OK turn the water heater on...OK, now turn it off."
Where do you have water leaks in the fresh water system???
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
Old 03-29-2009, 04:17 PM   #8
Mike Leary's Avatar
Images: 11
Nope, a Dometic "Classic", either a 2620 or 2820, operates on propane or 120 volt. Switches automatically. Not sure if you've got the same size as our mo/ho; but worth a check. Dometic.com
Old 03-29-2009, 05:04 PM   #9
Baltimore , Maryland
Jason, you can always pretend you still have a tent and use coolers. Another option is to put a block of ice in the fridge. You make it to CBR and someone there will scratch their head enough to figure it out. Do not fret, someone will help fill any of your needs there. I hooked up my water today and found water pouring out the bottom. Nothing like getting ready to go out for the first time. Looking forward to seeing you Thursday. Frank
Old 03-29-2009, 08:13 PM   #10
WineStream's Avatar
2005 30' Safari
Images: 24
update...any more ideas
Well, the fridge is vindicated from the fuse blowing issue. I completely disconnected the 12V circuit of the fridge and connected it to a battery directly (with a 20A fuse in-line) and it didn't blow the fuse. However, it still is doing the constant igniter snapping. There's something else in the circuit that's all of a sudden blowing the fuse, but that's a topic for another forum.
I haven't taken the advice to stand outside and see where the arc is grounding (it's late, it's windy, it's cold) so I can't answer that suggestion yet. Anyone else out there with ideas? I think this fridge is old enough that it shouldn't have a circuit board controller. I hate to take it to have it serviced (would have to give my first born plus one arm, I think), but it kinda blows having a high dollar piece of hardware that doesn't work how it should and thus prevents me from having the 100% best camping experience.
Old 03-29-2009, 09:50 PM   #11
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
The RM2501 from our '66 Safari ran in the shop for two days on a barbeque bottle and regulator and 12 volts from a small battery charger. No way it needs 20 amps DC to run on propane. It was a 6 amp battery charger, and the meter on the charger didn't read any current at all.
The test run (following reinstallation of the rebuilt cooling unit) was quite successful. The igniter did not spark so long as there was a flame present. It sparked and re-lit the burner instantly when the flame was deliberately blown out with compressed air.
Testing is complete, so we're about to reinstall it in the Safari.
Hope this gives you some info on how it's supposed to work.
Old 03-30-2009, 07:57 PM   #12
WineStream's Avatar
2005 30' Safari
Images: 24
Well, the electrical gremlin is found. I'll spare the details, but the gremlin was the positive circuit wire feeding the oven light. Yes, the friggin' over light circuit was my fuse blowing issue. I yanked the wires and found that the positive wire was grounding against the oven frame. There was a very small portion of the sheath rubbed away from years of traveling. I needed an excuse to toss that space-taker-upper oven anyway. So, I guess I can plug everything back up on the fridge circuit. I guess I will listen to it pop all the time at CBR and get it properly fixed later, or maybe someone at CBR will have a good idea.
Old 03-31-2009, 02:53 AM   #13
someone will have an idea. Sometimes they are good and sometimes not so good.
Old 03-31-2009, 07:34 AM   #14
HowieE's Avatar
Images: 12
Lets talk at CBR.
2004 Excursion 4x4
Dometic igniter parts wanted Alumanutz Refrigerators 1 07-27-2008 04:27 AM
Dometic flint-wheel / igniter fotochop Refrigerators 4 12-17-2007 01:16 PM
Furnace fan runs constantly rogerdavis Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-10-2006 04:25 AM
dometic rm2604 frig blows breaker 61landyacht 1960 - 1964 Overlander 2 05-19-2006 06:32 AM
28' CCD: Right turn signal blows fuse michaero 2002 - 2005 International 4 11-30-2004 09:09 AM
