Old 08-29-2011, 02:47 PM   #1
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Angry Dometic RM100 AC heater, big trouble
I went to preheat my fridge on electric before a week long camping trip, it
started to cool down just fine, couple hours later it was warm,
Then noticed my AC power was off, and the 30 AMP breaker had turned off.
Reset the breaker, but fridge did not cool..
Switched to gas and all OK
After the trip opened up the fridge back, checked continuity, heater dead, and leakage to frame. OK, tried to remove the bad heater and it almost
was burned off where it goes into a hidden metal holder, slight tug and it broke off..
I downloaded two manuals for this model and it is not clear how that
heater goes in.
Question, has anyone had this problem and removed the old heater, it feels like it welded to the bracket. Any other solution other then stay on gas?
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 08-29-2011, 02:50 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
How old is the fridge?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-29-2011, 02:53 PM   #3
WBCCI 8562
1975 31' Sovereign
HI, the RM100 is original 1975 vintage. Yes it would be great to replace it,
however $1200 bucks is a bit dear right now./
Old 08-29-2011, 03:10 PM   #4
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
on mine it seemed to have to holders for a heater. I don't know if someboby replaced the cooling unit but it had another holder that i figure was for a 12 volt heating element. The heter just sat in the holder.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 08-29-2011, 03:11 PM   #5
Mike Leary's Avatar
Images: 11
Bite the bullet and run it on propane. It will cost more than $1200 after you have it installed (we know, dearly).We had ours replaced this year: 2K parts and labor.
Old 08-29-2011, 03:23 PM   #6
dznf0g's Avatar
Oswego , Illinois
Does the element slide down a tube welded onto the cooling unit tube? On mine, the element tube is open at the top and bottom. I would remove the fridge, so I could get at it better, remove the chimney, and CAREFULLY work the old bits out with a rod about the same diameter as the element. If it won't budge, you may take it to someone who has a large reamer or drill bit to reach the broken off piece.
I wouldn't beat the heck out of it, (and of course support the cooling unit well) or you may let out all the smelly yellow stuff.
Old 08-29-2011, 03:26 PM   #7
Mike Leary's Avatar
Images: 11
I have heard of folks removing the fridge and dumping it up-side down to purge it, but, geez, time takes it's toll.
Old 08-29-2011, 03:29 PM   #8
1974 Argosy 20
Kooskia , Idaho
It will take a major removal of the entire refrigerator to get at the "chimney" that has the broken off 120 volt heater in it. Then you will still have to take the sheet metal and insulation off the chimney and hope you can get the remaining part out. Quite frankly I think you would be better off just running it on propane until the entire unit dies, then replace it with a new one. Propane is not a big expense on a refrigerator, especially compared to the cost of repairs on this one or a new one. I use my Argosy a lot, and virtually never bother to put the fridge on electric. Light it and forget it for the trip.
Old 08-29-2011, 03:42 PM   #9
Mike Leary's Avatar
Images: 11
Can the old re-fridges run on propane on the road?
Old 08-29-2011, 03:54 PM   #10
Airstream Newbie
Torrance , California
The trailer we had when I was a kid (an old late 60's Nomad) ran propane all day long while travelling down the road. I believe as long as you're able to keep the fridge more or less level it'll be happy.. This seemed to hold true for the fridge in our '01 trailer (non AS) as well.. as long as it had 12V and propane you're good to go (or a pilot light on the much older models)
Rick F is offline   Reply With Quote
Old 08-30-2011, 08:36 AM   #11
WBCCI 8562
1975 31' Sovereign
Thanks all, I agree, fooling around taking the fridge out, drilling out old heater, look's like a recipe for disaster. So keep a lookout for a good used replacement
fridge is now in the works. Have done well looking for wrecks being parted out.
I have always run the fridge on propane while on the road, here in Az most camp areas are 3 to 5 hour drive, in 100 degree plus heat.
So make a mad dash for the "Rim" and 7000 feet.
Old 08-30-2011, 10:20 AM   #12
1977 Argosy 24
Milltown , Wisconsin
A friend of mine had the same problem. He soaked the heating element in PB Blaster (penetrating Oil) for a few days and by tapping on it with a deep well socket the same diameter as the element he got it out. Put a new element in and it still works like a champ.
ventport is offline   Reply With Quote
Old 09-25-2011, 03:42 PM   #13
WBCCI 8562
1975 31' Sovereign
I pulled the fridge out..it needs other things done as well. I see a hole for the 12 volt
heater option (never installed) will the 120 volt heater fit in this hole???
Also has not been cooling great on gas, looks like sheet metal around vent stack is eaten away, so will fix that while I am at it.
Question, can I put the 110 heater in the 12 volt hole???
Old 09-25-2011, 03:44 PM   #14
WBCCI 8562
1975 31' Sovereign
Quick fix of course, anyone got a good used 2820 Dometic of equal ???/
55 1/2 tall, 8 cu ft..
Need help on installing Dometic RM100 fridge door seals carol4266 Refrigerators 3 03-24-2017 10:21 AM
Dometic RM100 Fridge carol4266 Refrigerators 0 07-26-2011 10:57 AM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Dometic RM100 not working mmcpherson Refrigerators 21 04-28-2011 08:37 AM
