Old 09-25-2011, 03:58 PM   #15
1974 Argosy 20
Kooskia , Idaho
If you went to a dealer in Dometic parts and the 120 volt and 12 volt elements for your model are the same diameter and length (they got them both out for you to compare) then I would not see any reason that you could not put a 120 volt element in the 12 volt element location. I would not do it if the original elements were not identical other than voltage.
Old 09-30-2011, 10:53 AM   #16
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Follow up, got a new heater rod, reamed the rust out of the extra tube as
impossible to get the old heater out with out damage. Works great. While I had the fridg out, discovered the area around the gas burner all rusted out, redid this are with galvanized sheet metal. Once the wind dies down here will check that out..was not cooling well on gas, figure I was loosing most of the heat.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Need help on installing Dometic RM100 fridge door seals carol4266 Refrigerators 3 03-24-2017 10:21 AM
Dometic RM100 Fridge carol4266 Refrigerators 0 07-26-2011 10:57 AM
Water heater won't lite aswbe Water Heaters, Filters & Pumps 6 06-06-2011 09:18 PM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Dometic RM100 not working mmcpherson Refrigerators 21 04-28-2011 08:37 AM
