Originally Posted by twitcher
The door on my Dometic fridge is warp causing the bottom to stay out about 1/8 inch. It is an RM 77 and it works great still. Is there any way to straighten the door? Would a latch at the bottom help? Any ideas?
Jordan
My first thought would be to remove the door and place it on a flat surface, use a 1x2 on the "low" corner, and push down on the "high" corners, to bend it back into shape. If that doesn't work, you will probably have to get a new fridge door.
