Old 06-24-2006, 07:13 PM   #29
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
now the control wires are reinstalled and covered with the foil tape.
you call them ferrets, i call them weasels.
Old 06-24-2006, 07:13 PM   #30
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
beer run, be right back!
john
Old 06-24-2006, 07:21 PM   #31
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
at this point control wires get routed back to the box, wire ties added to secure them.
then all the covers go back on the burner.
now the fridge is ready to go back in the trailer!
Old 06-24-2006, 07:25 PM   #32
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
after getting my neighbor dave to help me move the fridge back into my trailer i took a couple seconds to enlarge the opening with a block plane to make it easier on us guys.
this photo shows the fridge about 3/4 of the way back in.
at this point i installed new weather strip to keep any carbon monoxide out of the living quarters in case the fridge should malfunction!
important!
Old 06-24-2006, 07:27 PM   #33
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
new stainless screws to secure the unit...
Old 06-24-2006, 07:28 PM   #34
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
now the thermostat goes back in and the drip tray is reinstalled.
note the bend in the thermostat wire so it too drips into the pan...
ID:	22773   Click image for larger version
Old 06-24-2006, 07:30 PM   #35
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
now the freezer plate goes back in with more thermal mastic.
ID:	22775   Click image for larger version
Old 06-24-2006, 07:33 PM   #36
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
after reconnecting the gas 12 volt and 120 volt i fired it up on electric, then i re installed the doors.
getting close now!
ID:	22778   Click image for larger version
Old 06-24-2006, 07:35 PM   #37
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
after about one and a half hours of clean up and putting tools away i checked the freezer and found it was cooling nicely!
Old 06-24-2006, 07:37 PM   #38
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
once i figured i wasn't going to pull the fridge out again and everything was working i caulked the bottom of the fridge.
this too is important to keep carbon monoxide out of the trailer!
Old 06-24-2006, 07:38 PM   #39
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
lastly i check the gas operation, nice blue flame!
Old 06-24-2006, 07:43 PM   #40
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
so to sum it up in the time it took me to post this the fridge has cooled to 40 degrees and started to freeze water in the ice cube trays!
pretty good i think!
all i have left to do now is reinstalling the freshly painted shelves tommorrow!
john
Old 06-24-2006, 08:25 PM   #41
RickStream's Avatar
1974 31' Excella 500
, Wisconsin
Tech. side of the job.
John,
Great work, I am curious as to the amount of beer it took to finish this job off? If my frig. ever goes south I will need an ice cooler large enough to hold the correct amount to finish the job, what is this amount?
RickStream is offline   Reply With Quote
Old 06-24-2006, 08:33 PM   #42
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Originally Posted by RickStream
John,
rick
this was about a 12 beer job, a small cooler will do!
about a 5 on a scale of 10, no major hand tools are needed except the 3 foot crowbar!
john
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
