Old 05-12-2014, 05:34 AM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I was wondering if the narrower 1971 model would have had narrow (or shallower) overhead cabinets than the newer wide body units? If the roof lockers are shallower, that could mean more custom cabinet work for a finished look.
Old 05-12-2014, 08:37 AM   #16
duckdave's Avatar
1971 31' Sovereign
2006 22' Parkway
Little Rock , Arkansas
Mine's an 1979. I believe it is 8 foot wide. I thought they were all the same width?
duckdave
wdwessinger[at]me.com
1979 31' Sovereign CB
2010 GMC 2500HD Sierra Crew 4x Diesel
2006 Interstate
duckdave is offline   Reply With Quote
Old 05-12-2014, 08:58 AM   #17
Wise Elder
Jammer's Avatar
2010 30' Classic
A few things.
On fridges, because of those sorts of minor size changes over the years, it is fairly typical to have to make minor cabinetry modifications when changing out the fridge.
Dometic has several models in that size range with the RM3762 being the newest. Price is comparable.
I have ordered from Adventure RV. They're OK and do have good prices however I have had problems with items taking longer than they should to ship, and have not been impressed with their customer service. I still use them occasionally if I'm not in a hurry. I've had better luck with Tweety's, Out of Doors mart, and Vintage Trailer Supply.
Old 05-12-2014, 10:13 AM   #18
duckdave's Avatar
1971 31' Sovereign
2006 22' Parkway
Thanks, Jammer.
I ended up getting the RM2820, which is closest in size to the original RM100. There is a comparison of the sizes under post #5 of this thread. So far most of my modifications are due to replacing panels that have deteriorated, although I expect to have to make some modifications.
I did purchase from Adventure RV. I got the best price by far, and the new unit was delivered in under 5 days.
Best,
-duckdave
duckdave
2006 Interstate
Old 07-09-2014, 02:13 PM   #19
duckdave's Avatar
1971 31' Sovereign
2006 22' Parkway
I'm going to close out this report on the install of my RM2820. In the end the new unit caused the bottom of the China Cabinet to be about 1/2 to 3/4 inches higher, which called for redoing the interior shelving a bit, and downsizing the sliding doors. That part was not as difficult as it seemed at the start. Basically, just fiddling with the parts and piecing them together. Running 12 VDC to the cabinet turned out to be easy since there was an outlet in the credenza next to the fridge. I ended up buying the panels that finish off the front of the freezer and fridge doors. Looks nice, but I could have probably bought 2 pieces of black plexiglass for less (maybe not?).
I have just one remaining issue. The "case cover" that goes across the front of the fridge at the bottom (basically, just a strip of metal to close off the gap at the bottom) is too tall and won't fit under the hinges. Trying to get with Dometic to see if I have the wrong part. I suspect I'll be "adjusting" yet another part to fit in the end.
Over all we are very happy with the new fridge. Took it out for a spin on a trip to the Outer Banks and back for 2 weeks. I love not having to get down on the floor with a flashlight to start the fridge up, and the automatic switch from electric to gas is handy too.
Carry on!
duckdave
2006 Interstate
Old 08-13-2014, 10:54 AM   #20
Oakland , California
Originally Posted by duckdave View Post
i'm looking for a replacement for my 1979 dometic rm100 (1979-31' sovereign, mid-bath). Using the replacement table provided by dometic, i quickly determined that the rm2820 would be a nice fit. According to that chart, the rm 100 is (hxwxd, inches) 55 7/8 x 23 11/16 x 24; and the rm2820 is 55 3/8 x 23 5/8 x 24. Pretty close---1/16" under on height and width---i can certainly live with this.
Further research…including dometic's site sometimes lists the rm2820 (rm2820 classic---are these the same?) as 57 7/8 x 24 39/64 x 24 9/16. That's quite a difference! Pretty hard to squeeze those extra two inches into a 55 7/8" hole. So which is it?
Further research…suggests that the rm2820 may not even be available any more.
So what to do? I'm pretty sure a new fridge is in my future. I've repaired the old one at least once and got a couple extra years out of it (marginal performance) and it's 35 years old for crying-out-loud. I know i might be able to find a new back unit (though these are getting very hard to find), but i think i'm ready for a simple r & r (remove and replace) with a new one.
I need to figure out what will fit in my fridge slot, and is it available. Recommendations about particularly helpful vendors, or places with particularly reasonable prices for purchase and shipping welcomed.
Oh, i see i need to update my sig lines. I'm now towing with a 2010 gmc 2400hd diesel.
,Click image for larger version
Name:	ImageUploadedByAirstream Forums1407948872.885043.jpg
Liviastein is offline   Reply With Quote
Old 08-13-2014, 10:55 AM   #21
Would your chart include any info about the size hole for a 1974 sovereign
Thanks, livia
Disk brake conversion - Who is best and long term parts availability? perryg114 Brakes & Brake Controllers 56 02-11-2014 08:30 PM
WBCCI number availability? blucloud WBCCI Forum 11 08-07-2004 05:50 PM
rear bumper (57-62) availability ? p.dow Bumpers & Bumper Storage 3 03-16-2004 11:48 AM
Dometic Frig seals replacements davidlaxson Refrigerators 3 12-08-2003 09:33 AM
Safari Availability JLD 1974 - 1979 Safari 4 09-12-2002 08:32 AM
