Old 05-10-2005, 05:02 PM   #1
Thumbs up Dometic Refrigerator-RM100
We have 1976 Soverign and it is in pretty good shape. The only problem that we seem to have is that when we use the refrigerator with gas we cannot get it set where it does not freeze everything in the refrigerator part.
We wondering if it may have something to do with the altitude as we are at over 9,000 feet.
It does not do this when it is run on electric.
Any ideas?
All help will be greatly appreciated. I have had a lot of frozen fresh vegetables lately
Deb
DClark is offline   Reply With Quote
Old 05-10-2005, 05:19 PM   #2
I seriously doubt altitude is an issue.
It would appear you have a broken thermostat. The older Dometics had two thermostats; One for gas, one for electricity. How many temperature knobs does your unit have?
joatmon is offline   Reply With Quote
Old 05-10-2005, 05:48 PM   #3
69 Silverback's Avatar
1969 27' Overlander
Firth , Nebraska
Hi Deb,
I am not a profesional rv service person, But I have some ideas for you from my service book. From what you indicate, it points to a problem with the thermostat, the knob you are turning to try to regulate the temp. It could be a faulty thermostat, an incorrectly locatedend of the thermostat capillary tube , an incorrect size of the bypass screw, or dirt in the thermostat valve.
The good thing is that from, your description , the cooling unit itself is ok, because you say it works fine on electric.
There are still parts available for the RM 100. Do an internet search.
Here is a # for Dometic technical service 219-463-4858.
Good luck
Loren
69 Silverback is offline   Reply With Quote
Old 07-17-2005, 05:19 PM   #4
1990 34' Excella
Windcrest , Texas
Dometic RM 100 and others, Service Manual
Since I am in the process of replacing my thermocouple and magnet valve on our RM100, I thought I'd share this with the group. This appears to be the service manual for many of our models. Good luck everyone.
http://gasrefrigeration.net/dom_techdata/MAN_SM.PDF
Mitch
Swanny is offline   Reply With Quote
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1977 Dometic refridgerator overlander Refrigerators 30 03-14-2015 12:08 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
