Old 08-24-2004, 09:28 AM   #1
walter1's Avatar
1964 22' Safari
Foresthill , California
Dometic refrigerator on inverter power
Can I run a 2 way Dometic RM2551 120vAC / LP refrigerator off 1000 watt inverter power while towing and keep battery charged by tow vehicle? Still not warm and fuzzy about running on LP while towing.
Walter
walter1 is offline   Reply With Quote
Old 08-24-2004, 09:42 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
The original Dometic in my '67 Overlander (don't know the model) has a plate stating it requires 235 watts to run on AC.
So you could definitely run my refrigerator with your inverter. You are probably okay, but look around your unit & see if you can find a similar plate.
Your real problem will be feeding the inverter. Your charge line is probably only rated for 20 amps dc. 235 watts takes about 19-1/2 amps. Although your inverter is up to the challenge, your charge line may not be.
Tom
Old 08-24-2004, 10:25 AM   #3
Tinsel Loaf's Avatar
I have tried that with my Prosine 3000 and I found that most of the power goes to the refer and the inverter which consumes 60 watts above what the refer demands. So there was really very little or no battery charging going on while in tow. I now use just propane or just shut the refer off at a rest area when I know we will be filling the diesel tank at the next stop.
Tinsel Loaf is offline   Reply With Quote
Old 08-24-2004, 10:52 AM   #4
walter1's Avatar
1964 22' Safari
Thanks for the input, I'll check out my referig amp draw. Sounds like I keep coming back to run it on propane and be careful.
Walter
Power boost inverter? AV8 Electrical - Systems, Generators, Batteries & Solar 3 02-06-2004 08:50 PM
Bright idea for power savers Tinsel Loaf Electrical - Systems, Generators, Batteries & Solar 2 10-05-2003 06:48 PM
Newbie needs Classic 28' power management info Dave Jenkins Electrical - Systems, Generators, Batteries & Solar 3 07-24-2003 05:11 PM
connecting 110V system to inverter Cruiser Electrical - Systems, Generators, Batteries & Solar 4 07-16-2003 09:46 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
