1.I have an original Dometic Model RM 100. It will work on gas but I can't get it to work on electric. I have the wire diagram. Needing help with this.
First be sure that you have power to the outlet which supplies the refrigerator.
Second, check the heater element itself to see it has power to the leads that supply it.
Third, check the element to see if it is open (do it with a resistance check with a meter)
Forth, check back and tell us what you have found.
In my reply to your PM I completely forgot the simplest issue, which idroba listed first. Make sure the outlet is hot and the fridge is plugged into it.
— David
