Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 12-03-2018, 07:03 PM   #1
2016 23' Flying Cloud
Washington , Washington, D.C.
Dometic refrigerator ices up
The fridge in our 2016 Flying Cloud 23-foot is icing up around the freezer compartment. The inside of the freezer compartment is also frosty. This happens after about 2 days of operation.
I've tried reducing the amount of contents in freezer and fridge compartments. That didn't help.
This icing up happens on propane and electric. We keep the fridge running on propane while driving to new locations. I wipe out the ice crystals, but they just come back.
We kept the fridge on continuously for 7 weeks at a time this summer and 4 weeks this fall. Could that be the problem?
Is the refrigerator dying?
I am grateful for any solutions or advice!
bevmills is offline   Reply With Quote
Old 12-03-2018, 07:35 PM   #2
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
The ice/frost is formed from moisture in the air entering the fridge and freezer every time the door is opened. We have to defrost often twice in the summer. The RV reefers do not self-defrost.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 12-03-2018, 08:48 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
check the door seal. Leaking will cause frosting.
Richard
Old 12-04-2018, 12:42 PM   #4
1986 31' Sovereign
Miami , Florida
I spend the whole summer parked in Yellowstone which averages really low humidity. Usually get away with defrosting once. In the winter, we are in Florida where the humidity is, oh, 250% most days. We defrost every two to three weeks.
I know it is contra intuitive but if you fill your freezer as much as possible, you will reduce the amount of moisture laden air, reducing the rate that frost accumulates.
If you are getting ice on the fins in the refrigerator, a little spray bottle full of alcohol is handy to spray the ice off with.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Old 12-04-2018, 01:33 PM   #5
2013 30' Flying Cloud
Kingwood , Texas
Small fans on the cooling fins in the refrigerator will help in the refrigerator section and it helps distribute the cooling. We use two plastic place mats placed in the back of the freezer that allow the frost to attach to it and be easily removed.
DoubleR is offline   Reply With Quote
Old 12-04-2018, 04:31 PM   #6
Sag Harbor , New York
^^^ x2
Old 01-04-2019, 07:49 PM   #7
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
To defrost I use the wife’s hair dryer with a towel on the bottom of the freezer to soak up the water. I check the fins and do the same when I’ve forms on them. We have a drip pan with an outside drain under the fins so it ease to deice them. It’s the humidity in the air that causes the ice not the refrigerator.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 01-04-2019, 08:02 PM   #8
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Add a fan.
Adding a fan will prevent this problem. I live in the humid south and never have to defrost my fridge.
ID:	331091   Click image for larger version
ID:	331093   Click image for larger version
Model 50 Dometic Refrigerator blurdstr Refrigerators 3 08-26-2012 01:52 PM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Dometic Refrigerator scotta Airstream Motorhome Forums 1 03-16-2003 09:57 AM
