Dometic Door Handle spring Cheap Replacement
I found a spring that will work in the door handle of the 2010 refrigerator. The handle has a Tortion spring held in place by the rod that the handle rotates with. I found a cabinet latch that had a spring just a little bit larger and drilled out the pivot pin, retrieved the spring and bent the spring arms tighter so that the door handle would be under tension like the original. This fix cost me 15 min and $0.98 to complete. No more $22 latches for me!
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
