Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 06-27-2016, 01:14 PM   #1
ReggieDaniel
1972 27' Overlander
charlotte , North Carolina
Dometic Refrigerator - 1972 International
Finally got around to trying out the propane refrigerator in my AS and the striker is frozen up, won't turn. I don't see any way to work around this by lighting it from the backside. What are my options or do I have to take it completely out to get to it? Oven and range work good, going to try the water heater next but really want the refer to work too.
ReggieDaniel is offline   Reply With Quote
Old 06-27-2016, 01:24 PM   #2
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
Is it a RM75? I lit mine from the back.
CaCraig is offline   Reply With Quote
Old 06-28-2016, 05:47 AM   #3
ReggieDaniel
1972 27' Overlander
It's an RM-60.
Old 06-28-2016, 07:34 AM   #4
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
My RM100 has a small opening at the bottom of the flue stack with a sliding door.
Old 06-28-2016, 12:21 PM   #5
1967 26' Overlander
Spartanburg , South Carolina
My '67 Overlander has the original Dometic reefer which is now 50+years old. Some years ago the flint striker wheel wore out and no part was available. My son went on line and found a water heater "re-igniter" with a spring loaded manual switch which generates a spark from a 12 volt source. I installed it near the front and under the reefer and ran a wire to a grill electrode mounted next to the burner close enough to spark to the edge of the burner. The flame lights when I trigger the switch on the re-igniter while holding the button for the pilot. Prior to that we had to open the outside access door, remove the wind baffle and use a match which required a second person to hold the pilot button inside.
Jacob D is offline   Reply With Quote
Old 06-28-2016, 04:25 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post a pic of the back of the refer?
Old 06-28-2016, 07:44 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The RM60 can be lit with a charcoal lighter from the back.
Make sure it is in the gas mode.
At the lower right hand corner there is a small flip open hatch. Rotate it to the left.
With the lighter in the right hand ready to ignite.
Hold the red button on the safety valve up, stick the lighter in the hole and pull the trigger.
It may take several attempts.
Once the burner is lit continue to hold the red button up for a minute or so. If the thermocouple is wiring and seeing the flame the burner will stay lit when you release the button.
Old 06-28-2016, 10:05 PM   #8
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
This is my old RM75. I would think the RM 60 would be similar.
Old 06-28-2016, 10:39 PM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Working not wiring!!
Old 06-29-2016, 05:57 AM   #10
ReggieDaniel
1972 27' Overlander
RM-60 Striker
Thanks all, I'll try it tonight and post my success or failure. First time AS owner so this is all new, this forum has been really good to read other folks challenges and solutions. I've uploaded a pic of the rear of my unit if anybody sees anything out of whack.
Old 08-26-2023, 07:39 PM   #11
69charger's Avatar
Different but similar problem
My 72 AS with a Dometic AC/gas refrig has been stored indoors for 3 years. Got it out and woke it up; everything working except the 'fridge.
Gas lights and burns properly, system makes the same liquid noises I recall, but there is no chilling of the freezer or the refrig compartment. I have not run it for HOURS, but I recall that there was some noticeable chill down of the freezer floor after an hour or two.
Ditto the same situation on AC.
In both configurations the condenser coils on the 'outside' above the 'fridge door are warm/ hot to the touch, as is the plumbing. Just no cooling.
Long term (about 5 hours) running of the fridge on AC resulted in the refrig coils inside being a little warm....no change to the freezer.
I've leveled and re-leveled the unit several times, running the tongue jack all the way up and down, and rocked the trailer from side to side, as I was told there may be a bubble stuck somewhere causing a vapor lock. I don't believe the coolant liquid has breached anything, as it is clearly still moving around in the pipes, with attendant liquid noises and heat in the pipes.
Any ideas? I recall being told to tow the trailer a few miles with it operating on gas to shake any vapor locks loose, but I've not done that yet.
Thanks in advance.
69charger is offline   Reply With Quote
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
Compact Home Refrigerator or RV Refrigerator? mattsteel Refrigerators 26 04-05-2011 01:30 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
1972 Dometic Refrigerator Value kneal Refrigerators 6 03-25-2007 12:07 PM
