Old 01-17-2012, 05:26 PM   #1
Boerne , Texas
Dometic Refrig no lights on panel
We are full timing, yesterday the fridge went on the fritz. It's a Dometic RM2820 and is 1.5 years old. The lights on the upper panel will not light up when the power button is pushed "on". After several hours I tried it and they lit up and the fridge worked but only for 5 min then all the lights went out again. There is good shore power and 12 power reads 13+V, I checked the two internal fuses and they were good.
I think it could be the main control board, what do you think??
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley.
Tow With: 2006 Dodge 2500 Quad Longbox 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr programmer, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Old 01-18-2012, 06:23 AM   #2
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I am no expert but it seems you should have lights even with a bad board. That panels lights run from DC power on I think. Where did you do your test that got your reading of 13+. You could get a reading on the DC wires where they attach to the board. Might just be a loose wire there. If not I have no clue.
Good luck,
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 01-18-2012, 08:41 AM   #3
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
The control board and display on the fridge require 12v. to operate. Have you opened the outside panel and checked for 12v at the connector there. If you don't have 12v there you may have a circuit breaker or fuse problem. I would suspect that before I would suspect the display panel.
Morgan guy is offline   Reply With Quote
Old 01-18-2012, 08:56 AM   #4
lewster's Avatar
Naples, FL , Hood River, OR
It's very rare for an upper board (called the 'eyebrow') to go out. I would concentrate on the wire harness connections or the lower control board itself. Remove the 'eyebrow' to be sure that the rear connector is plugged in all the way and that the wires going into it are all secure in the plug.
Then go to the lower control board and do the same. Be sure that all DC connections are clean and tight. If you find that all of the above are nominal, you are probably looking at a defective control board.
IIRC, your unit is covered under a 2 year factory warranty (check your owners' manual). If it is, you should have any factory authorized Dometic service center look at this, as you can void that warranty if you do it yourself.
Old 01-18-2012, 09:05 AM   #5
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
The buttons on ours actually are rubber covers over the real buttons. The rubber covers can become dislodged and not work. To solve that annoyance I took off the plate and repositioned the covers.
Since yours worked and then stopped working, I doubt this is the problem, but if nothing else works, it might be worth a shot. I just fixed a remote for a ceiling fan where the rubber buttons failed to work because they were somehow out of line or dirty or something—not sure what I really did, but after I put it back together it worked.
Gene
Old 01-20-2012, 04:01 PM   #6
Boerne , Texas
It was the control board. I think back a week or so ago and I remember that the fridge was not keeping temp well. It usually held temp below 40F but it crept upward and correcting it by increasing the number on the upper panel failed. That must have been the signs of the beginning of the failure.
I installed a Dinosaur Electronics board and it is back to cool again. There is a place in California that had great prices ...r&g electronics I think it was called.
James B.
Old 01-30-2014, 06:51 PM   #7
Boerne , Texas
It's at it again. It won't turn on again
Symptom: The on/off switch won't stay engaged. If I hold it in the fridge will start and run but when I let go it shuts off. I disassembled it and took apart the switch (advise not to) and freed up the switch. It has a light amount of grease inside and a really tiny spring witch went flying and I couldn't find it till the next day I found it on the bottom of my shoe. Well, it's back together and works again.
Name:	RM2820 upper panel.jpg
ID:	204645   Click image for larger version
Name:	RM2820 upper sw1 open.jpg
Name:	RM2820 upper sw1 closed.jpg
James B.
Top clearance lights on 13 panel whale tail? Sugarfoot Lights - Interior & Exterior 17 08-28-2011 04:01 PM
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
