Old 11-16-2006, 03:45 AM   #1
1997 33' Cutter Bus (Ford)
buffalo , New York
Dometic Refrig
I have a Airstream Cutter with a Dometic 2-way refrig.
The frig works well on shore power, but does not maintain cold on gas.
In troubleshooting the problem; checked the flu, presence of flame etc. it appeared that the flame was too low.
I pulled the regulator at the propane tank and found it full of a purple liquid. Thinking that this was causing a low pressure to the refrig. I changed out the regulator.
The frig worked well for a couple of weeks - now the problem has resurfaced.
Should I attempt to replace or clean the gas valve on the back of the frig.
Has anyone dealt with this problem before?
Perry Smith
Buffalo, NY
Garages is offline   Reply With Quote
Old 11-16-2006, 04:02 AM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I would concentrate on the burner assembly. Between the assembly & the gas-side thermostat, there are two, different orifi (jets). One orifice meters gas for Pilot mode, and the other meters gas for Cool mode.
Tom
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Refrig pressure gauge. casarodante Refrigerators 5 07-08-2002 11:04 AM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
