Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 03-23-2007, 09:05 PM   #1
wasafari
Profile:  2003 25' Safari
spokane , Washington
dometic refer recall update
Well wonder of wonders after 6 months Dometic has (almost) the parts on hand to fix the burners. Great reading the notice, if your refer shows any symptoms of leaking, don't use it. If your's DOESN'T show any symptoms, you can use it on electric, sort of, well maybe not, actually we don't recommend using it till it's fixed!!!!! Okay, but if it is such a problem, how come we could use them (on gas no less!) after the initial notice went out? Bet it's going to be crowded at the old service center.....parts are SUPPOSED to be available as of 4/16/07.
wasafari is offline   Reply With Quote
Old 03-23-2007, 09:22 PM   #2
sequoiacoast
sequoiacoast's Avatar
Profile:  1968 24' Tradewind
Eureka , California
I may be slow (sorry) but which Dometic models have been recalled?
sequoiacoast is offline   Reply With Quote
Old 03-23-2007, 09:58 PM   #3
mistral blue
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
See: RV.Net Open Roads Forum: Dometic Refer Recall - Possible Fire Hazard -Update 2/13/07
See also the thread entitled: Huge Dometic Refrigerator Recall Announced:
(Sorry, I don't know how to highlight threads yet.)
mistral blue is offline   Reply With Quote
Old 03-23-2007, 10:38 PM   #4
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
What's interesting was the fact that I got a recall letter, but the letter truly doesn't say that my refrigerator is defective. It depends upon your serial number, and mine was not one in the range that was stated. I was surprised that Dometic apparenty doesn't have the serial number of my refrigerator in their records. I figured that since I sent in the warranty cards, this would be a given. So I guess a lot of us will get that letter and hold our breaths while we check out our serial numbers.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 03-23-2007, 10:43 PM   #5
SilverToy
Profile:  1992 34' Limited
Falls Church , Virginia
Broom, rug... sound familiar?
Is it just me...? Or does this sound like a broom & rug deal... Sorta like 'the general', ford, etc... have done umpteen zillion times in the past... not that this sorta thing is limited to auto makers.... Heaven knows it isn't!
Is it just me?
Wondering....
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 03-24-2007, 09:17 AM   #6
sequoiacoast
Eureka , California
It looks like the recall involves only 2- door models.
Old 04-06-2007, 10:19 PM   #7
codybear
codybear's Avatar
Profile:  1964 22' Safari
SACRAMENTO , California
Images: 53
Hi,
I saw that our Dometic 2 door refrigerator was indeed on the recall list..I called to schedule a fix and I was put on a call-back list for about a month..in the mean time, I was told to be wary of any ammonia smell, to look for yellow residue on the sides or back of refrigerator,and if the refrigerator is cooling properly. has anyone else gotten this far?..my unit was made in 1999.
Stop and experience life.
You are invited to view my Blog:
http://berrytarts.blogspot.com/
codybear is offline   Reply With Quote
Old 04-07-2007, 06:46 AM   #8
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Originally Posted by codybear
Hi,
Once you get to this point, that is......you smell ammonia or the yellow sodium chromate is visible at the back of your fridge, the cooling unit has been compromised and the refrigerant has leaked out.
Your unit will not cool, even though the controls will say that it's operating. In this situation, you need a new cooling unit! The recall involves a possible leak point in the boiler tube that is very close to the propane heat source. If a leak occurs while running on LP, the flame could ignite the escaping hydroden from the refrigerant leak and cause a fire. This is why the recall letter tells you to turn off your LP supply screw at the gas valve and only run on electric.
I have not seen any repair parts yet and I have about 30 units on my list to date. This is reminiscent of the Norcold recall of several years ago, where we were out there replacing entire cooling units by the dozens.
This fix, as I have been told, involves re-positioning the sleeve for the burner tube in the boiler section with a new part, but I have not seen it yet so I really have no actual data.
I will post again as soon as I get the first repair parts.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 04-07-2007, 06:55 AM   #9
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I have to say, we've know about this for several months now (5 or 6??).
It concerns me greatly that we are now upon the start of the camping season and there are at this point, no clear indications of any action yet, just a lot of talk from Dometic. If it were simply that the unit stopped working, I'd be less concerned, but the whole point of having a fridge is to keep stuff cold and there is a potential for fire if we run our fridge. We boondock freq, so what to do this season if we can't run the darn thing on LP? Risk the possibility of all the stars and planet coming together for the perfect storm and loose my Airstream, it's contents or life itself??
Just venting here, not in anyone's specific direction, excecpt for the poor response from Dometic on this issue.
Old 04-07-2007, 10:15 AM   #10
Safari64
Safari64's Avatar
Eagle River , Alaska
2-door only??
Is this the case:
This applies only to 2-door models??
We can save me and others a whole lot of reading and investigation if so.
Safari64
Safari64 is offline   Reply With Quote
Old 04-07-2007, 12:27 PM   #11
dieterdog
Profile:  2004 16' International CCD
1997 25' Safari
hamilton , Montana
Lew,, have a 1997 fridge that is on the recall list,,, it does exhibit the amonia odor,, does that mean ideally a new refrigerator would be the best solution??? cost is high i realize,,, but want to be safe,, thanks ,, donna
dieterdog is offline   Reply With Quote
Old 04-07-2007, 01:00 PM   #12
Silvertwinkie
Aluminut
If yer smelling ammonia, particularly from the outside, I'd not use the unit, esp the LP setting!
Old 04-07-2007, 06:40 PM   #13
lewster
Commercial Vendor
lewster's Avatar
Hi Donna,
Ammonia = LEAK in the cooling unit. There isn't much refrigerant mix contained in these units, so if you smell ammonia or see the yellow sodium chromate, your cooler is CAPUT! (gone for those in the audience that don't speak German )
A replacement cooling unit is way cheaper than a total replacement fridge, but that call is left up to you and usually depends on the general condition of the box itself. Since the entire fridge has to be removed and placed face down on the floor to remove and replace the cooling unit (generally easier than moving the fridge outside the trailer), it 'might' be a better economic decision to get a new fridge with a new 3 year warranty.
These are the facts; the ultimate decision is yours!
AIR # 10325
Old 04-07-2007, 09:36 PM   #14
wasafari
Hey Twink,
my feelings exactly. From what I read on the recall update, unless you are wide awake and sitting in a parked trailer with a fire extinguisher in hand they DON'T EVEN WANT YOU TO USE IT ON ELECTRIC!!!!!. Nice timing, guess they couldn't have gotten it together during the WINTER........
removing Dometic Refrigerator smily Refrigerators 14 10-29-2007 04:01 PM
Looking for Refer. Door Shelf InsideOut Parts Archive 23 06-17-2004 06:08 PM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
