Mark,
The Gauge you refer to is a LP pressure gauge. It will move a little when the refer goes on gas. AS long as it does not drop below 11 WC the refer should work.
Has the refer lit on gas? like rog said it could be air in the lines if the tanks have been recently filled. If the gas pressure drops below 11 WC the gas valve may not stay open. That would require some work on the LP regulator to fix
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
