I understand that you found your problem and it appears I share the same. I do plan on replacing the igniter. Here is a troubleshooter that I found on-line.
Electronic Igniter
The electronic igniter (below) changes 12 volt DC power supplied to it by a switch or circuit board into a high voltage spark between the electrode and burner head. There are slight variations of this igniter, the Channel Gaslighter Mark 6, but if you have one that looks relatively similar, you're in the right place. There is also
another style a little farther below.
When 12 volt is applied to the "+" and "G" (-) terminals of the igniter, the igniter monitors the resistance between the electrode and the burner. If there is no flame at the burner, the resistance is high and the igniter sends high voltage through the spark wire to the electrode. The high voltage jumps the gap between the electrode and burner and sparking begins. When the flame lights, the resistance between the electrode and burner decreases, the igniter senses this and quits sending high voltage to the electrode. If the flame goes out, the igniter will resume sparking again and usually relight the flame.
When the igniter is sparking, the "L" terminal sends a pulsing high voltage DC signal to whatever it is connected to. The "L" terminal could be connected to an ignition light or to a circuit board.
Troubleshooting. If there is no spark at the burner, first remember that the igniter senses the resistance between the burner and the electrode. If the electrode is cracked (even hairline) or wet, it will ground out and make the igniter "think" the flame is lit, and therefore not spark. The spark wire can also have similar problems. To test for a cracked electrode, disconnect the spark wire from the electrode and set the refrigerator controls to the position where sparking normally occurs. If the wire sparks to a metal part of the refrigerator, the electrode is bad. Before performing this test, however, if an electronic gas valve is involved in the system, locate the manual propane shut off valve at the back of the refrigerator and turn it off so propane is not allowed to flow and accumulate. Also, check the gap between the electrode and the burner. It should be about 3/16".
