Old 10-21-2004, 07:56 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Dometic Questions
1975 Tradwind 25í
Unit works great on AC. Unit does at all on Gas?
Does the AC current need to be disconnected prior to attempting to light on gas?
Is there a trick to igniting, other than be patient?
Have tried to several times to light ant to be honest canít see the if the pilot is actually lit?
balrgn is offline   Reply With Quote
Old 10-21-2004, 08:36 AM   #2
Balrgn
Propane appliances have several safety features that kick-in when attempting to switch to propane from AC. One such feature on my '73 prevents the use of propane by restricting the turning of the propane on-off
valve until the AC switch is turned to off.
Second, propane will not flow when the unit detects a problem with pressure in the line.
If you have pressure in the line (simple test: do the other appliances work on propane?), then most likely the control unit is preventing the gas from flowing to the pilot. A certified mechanic should check this to see if the control unit needs to be replaced.
Sometimes the pilot will not light until all the air is evacuated from the line and gas is able to flow. Hold the pilot button down until gas flows and the pilot light is lighted. If the pilot light does not light after a "long" time, the control unit make be the problem, or the problem may be a blocked orifice. In either case, a certified mechanic could check this for you.
I know it is difficult to see if the pilot light has lighted, so when I have a problem trying to light the pilot, I will go out at dark which greatly increases my ability to see any glow created by the pilot.
Rick Alston is offline   Reply With Quote
Old 10-21-2004, 08:56 AM   #3
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
Rick makes some good points. My Dometic refer (it's about three years old) has a switch on the front panel for gas/electric.
Before trying to light the more difficult gas appliances like the refer and hot water heater I light a couple of gas stovetop burners first and let them run a minute to help purge air out of the lines.
Moonshot is offline   Reply With Quote
Old 10-22-2004, 08:56 AM   #4
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Dometic Follow up
Thanks for the tips. I got it working!
Pulled the panel to look over the fittings. I then noticed that the supply valve was not opening all the way. Made the adjustment, took apart some of the fittings to check for blockage, open the supply to verify the gas was flowing. Assembled and checked each fitting. Lit the pilot manually. Turned the controls to MAX. After an hour (checking the flame every so often) The freezer is COLD!!!!!!!! What a relief!
Old 11-09-2004, 10:53 PM   #5
Hippo's Avatar
Battle Ground , Washington
My 1975 Tradewind Refer will not work on AC, works great on propane. I replaced the toggle switch on the back of the refer but will still not work on AC.
Any ideas or help.
WBCC#7854
Hippo is offline   Reply With Quote
Old 11-09-2004, 10:58 PM   #6
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Any ideas or help.
WBCC#7854
There is an electric heater element above the burner flu, hidden behind metal covers.
Follow the wires into the metal shrouding over the burner flu, and you will find an electric heater probe. This is a likely problem if your fridge will not work on 120V.
before removal, check if the heater element gets 120V with a multimeter.
If not,let us know and we'll go form there.
Good luck,
Uwe
www.area63productions.com
Two Door Dometic Refrigerators Models, Parts, Data jaco Refrigerators 10 07-25-2009 04:12 PM
Dometic RM100 TGB96 Refrigerators 9 08-30-2004 12:38 PM
Airstream / extended stay questions krowsea Our Community 5 08-20-2004 04:35 AM
Need Dometic RM2201 fridge 85MH325 Refrigerators 0 07-24-2004 09:13 AM
Got it! And now the real questions begin... blackbox Airstream Motorhome Forums 18 02-18-2003 05:54 AM
