Old 04-16-2008, 07:13 PM   #1
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Dometic Problem
The door of the Dometic refridgerator in our 2008 International fell off.
Has anyone had a similar problem?
SRW
SRW is offline   Reply With Quote
Old 04-16-2008, 07:28 PM   #2
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Not yet, knock on wood. At least it's covered under warranty and ANY Dometic Authorized dealer or service center can perform the work.
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 04-16-2008, 07:54 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
SRW
SRW,
Just for informational purposes.......where exactly did the failure occur? Did the hinge crack? Did the door crack? Did the hinge pin snap?
Inquiring minds need to know (and so will Dometic when they replace it under your warranty!!!!)
Hope you get it fixed to your satisfaction and SOON!!!!!!!!!!!!
Old 04-16-2008, 08:12 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Were the chimps loose in your trailer?
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 04-16-2008, 08:14 PM   #5
Elgin , Texas
Images: 164
Nah, they already recaptured all those and they're back in their pens in Bastrop.
bake315 is offline   Reply With Quote
Old 04-17-2008, 10:39 AM   #6
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
Originally Posted by lewster
SRW,
For informational purposes only.....
The door got hung up at the lower door hinge. It became difficult to close and (I am guessing here) the trim at the lower left side of the box caused a piece of the door's trim to break at the lower left corner of the door.
Trying to close the door slowly, very slowly, did not free the problem and only caused further breakage of the door's trim to the point where the entire door fell off.
Fortunately, I caught the door before if hit the floor.
Excepting for the door's locking handles falling off previously there were no indication that any further problem existed.
Since the door is now off of the fridge I can see the tiny (if not puny) pin that the door hinges on.
SRW
Old 04-17-2008, 11:10 AM   #7
Crusty's Avatar
1992 34' Excella
I used to have a barn door that would fall off of its hinges every time a horse would scratch his butt on the corner - any similarities to your situation?
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 04-17-2008, 11:57 AM   #8
Cloud10
smccollister's Avatar
2010 25' FB Flying Cloud
Tualatin , Oregon
Images: 12
Send a message via Skype™ to smccollister
Hi,
Yes, we've had problems with our Fridge door (2004 Intl). Not with the door hinges, but with the stainless face plate and the trim that holds it in place.
The stainless panel on the front is heavy - and is held in place by a thin plastic lip around the edges. The lip at the bottom holds the weight of the stainless face and failed.
Since under warranty, we had the shop cover the repair/perform the work. The first attempt involved re-gluing the bottom strip in place and that failed after a month or so.
On the 2nd trip into repair, the bottom lip was reinforced with rivets to help hold the trim in place. So far that seems to have done the trick, but it does seem to be a design flaw. Since we have the 16ft Bambi, our fridge is probably different size than yours, so maybe it is unique to the smaller ones - haven't heard about other's experience with this.
Scott
smccollister is offline   Reply With Quote
Old 04-17-2008, 07:42 PM   #9
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
No chimps only two cats.
I have spoken with my AS dealer and so far they have no information as to when the door will be repaired/replaced.
SRW
Old 04-17-2008, 07:49 PM   #10
Westfalia's Avatar
Images: 35
If the dealer can't fix it in a timely manner, seek out ANY other Dometic repair shop.
Old 04-17-2008, 07:50 PM   #11
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
SRW
If you're dealing with Camper Clinic II (Buda), be careful and double check everything they do. There's been several threads about them here (and personal experience, to).
I think I know where the chimps ended up...
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 04-18-2008, 01:08 PM   #12
happycamper2's Avatar
2009 25' FB Flying Cloud
Anniston , Alabama
The top hinge was cracked on our 2008 when we bought it. We knew it was hard to open, but just thought the catch needed adjusting. We are going back to the dealer to have the door replaced.
happycamper2 is offline   Reply With Quote
Old 04-18-2008, 06:43 PM   #13
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
I appreciate your comment, but can say that the tech at CCII did a good job on a short punch list.
After seeing a few photos of the door taken by CCII, Dometic is sending a new door and the work will be completed on Tue/Wed next week.
We'll see.
SRW
Old 04-19-2008, 03:39 PM   #14
SRW
TEXAS66
SRW's Avatar
Georgetown , Texas
OK, so there are two cats and one insists on making sure that the coffee is up to his standard.
SRW
Name:	YOu check the coffee and I will check you.jpg
Dometic 75 - RM77 : Problem with how to... dufferin Refrigerators 7 07-02-2013 10:30 AM
Whats the problem getting the Dometic recall done on an Airstream? ROBERT CROSS Refrigerators 8 11-02-2007 12:29 PM
old dometic gas problem tinsltootsie Refrigerators 6 08-08-2007 06:06 PM
dometic fridge problem nightowlhooter1 Refrigerators 27 08-19-2006 05:06 PM
Silly Dometic refrigerator "problem" Toasty's Dad Refrigerators 0 12-20-2005 07:19 PM
