Old 08-16-2011, 05:50 AM   #1
1982 31' Excella
Burlington , Ontario
Dometic not working on 12V, ok Elec & Gas
Hi, 1982 Excella #1' with Dometic that works great on Elec and Gas but not at all on 12V.
Any ideas to help me trouble shoot this?
Anthony
afordjones is offline   Reply With Quote
Old 08-16-2011, 06:02 AM   #2
x
XXXX , XXXX
Anthony are you sure the fridge is a three way power fridge? Most trailers have two way fridges, propane gas and 110VAC electric. If the fridge is working on gas and electric you do have 12VDC power to the fridge which runs the circuit board.
If it is a three way fridge then you need to check the fridge circuit board for a blown fuse to the 12VDC heating element. I'll PM you a contact # and we can talk more.
wasagachris is offline   Reply With Quote
12v, dometic
Dometic 360 not working on gas mode. AWCHIEF Refrigerators 5 04-02-2012 05:05 AM
Elec Stab Jack Not working Coloradoair Jacks, Stabilizers, Lifting and Leveling 22 03-15-2011 11:42 PM
What fitting for GAS on Atwood gas/elec WH rlindberg Water Heaters, Filters & Pumps 1 04-09-2010 11:29 PM
Intermittent 12v elec problem & solution ole81 General Interior Topics 4 07-29-2007 10:01 AM
help, 12v center light not working. garthbf Electrical - Systems, Generators, Batteries & Solar 4 08-15-2006 05:36 PM
