Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-09-2006, 07:40 PM   #1
ipso_facto
Profile:
Dometic: Is my flame out?
That thing is following the usual pattern of 3 days cold, 3 days room temperature....
I finally found the "flue"... it's a 3-ft long pipe in the back. I touched it and it's completely cold. I couldn't find a warm spot anywhere, not even the bottom. Does this mean my flame is out, and by going out is causing this warm problem?
This has been going on for a while, last year I had the freezer very cold and the fridge intermittently warm. This year everything alternates between cold/warm.
1986 Excella, 32' - FOR SALE ON EBAY, AUCTION # 160034864277
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 04-09-2006, 09:00 PM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Ips,
When operating properly, the round tube above the LP burner (flue tube) should be at about 120-130 degrees, as should the absorber coils (the down sloping section of tubing in the center above the large reservoir). If they are cold....you ain't got nuttin'!!
The refrigerant must me hot to operate correctly and cool your fridge. This means that the refrigerant must be heated either by the LP burner or by the electric element located in the burner tube. It is a silver rod sticking out of the tube about 8" above the bottom of the flue.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 04-09-2006, 10:48 PM   #3
wingfoot321
Profile:  1987 29' Sovereign
Sparta , Tennessee
Ipso,
There are four little screws that hold my galvanized steel wind screen in place. Very quick job to remove. Makes it easy to monitor if you are having problems.
I can touch mine with the back of my fingers at the lower part of the tube and tell if the flame is lit without removing the wind screen.
wingfoot321 is offline   Reply With Quote
removing Dometic Refrigerator smily Refrigerators 14 10-29-2007 04:01 PM
Flame out on Refrigerator When Traveling jcanavera 2001 Safari 8 12-07-2002 10:44 AM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 9 10-08-2002 04:08 PM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
