Old 05-31-2015, 12:06 PM   #1
1968 26' Overlander
Snowmass Village , Colorado
Dometic MB52 just freezing
Looking for some tips here. . .
I have a Dometic MB52 Fridge, and I can't get it to stop freezing everything. I have it on the lowest setting (barely on) and it's still freezing everything in the fridge. If I turn it any lower the fridge turns off. Any thoughts out there? Thanks!
ecasebeer is offline   Reply With Quote
Old 05-31-2015, 12:34 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Does it do that on both gas and electric? It will freeze up if the capillary tube breaks off at the thermostat. I had that happen with the same fridge and had to get a thermostat from a used fridge as they aren't made anymore.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
MB52 magnetic door gasket? ecasebeer Refrigerators 3 10-16-2014 06:55 AM
Just a few nights of freezing? ovrteakettle Winter Living 22 12-15-2009 01:50 PM
Dometic freezing main compartment Naturescalin Refrigerators 5 01-18-2007 01:22 PM
Travel in freezing weather jcanavera On The Road... 6 08-04-2003 08:10 AM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 01:33 PM
