Old 12-02-2009, 10:17 AM   #1
TheProfessor's Avatar
1966 26' Overlander
1966 26' Overlander
From Parts Unknown , Unknown
Dometic M52 (1966 vintage) drawings sought
Greeting Gang-
My 1966 Dometic M52 is working great... too great! On propane its freezing the heck outta everything. It will not switch to the Low Flame setting.
I am seeking some drawings of the thermostat (which I have lost due to a hard drive crash years ago), to open it up and clean it out. I recently replaced some gas line and some crud may have blown in to the assembly.
Any help would be deeply appreciated!! You can email any dometic pdf to me personally at : alex@nationalpodcastingcompany.com
Thanks gang!
TheProfessor is offline   Reply With Quote
Old 12-02-2009, 11:20 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
This should help. http://bryantrv.com/docs2/docs/M52.pdf
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 12-02-2009, 02:04 PM   #3
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
My M52 fridge on the 67, did the same because the capillary tube broke off at the thermostate control. I had to turn the fridge off and on as we drove to keep it from freezing everything. I got a new control and now it works fine.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 12-02-2009, 05:12 PM   #4
1966 26' Overlander
1966 26' Overlander
Doug-
Where did you get the replacement tube? Can you advise on Part Number? A vendor? I may have this issue!
Thanks in advance-
Alex8728
Old 12-02-2009, 06:07 PM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Originally Posted by alex8728 View Post
Doug-
Thanks in advance-
Alex8728
The tube isn't replaceable, It's part of the control. You have to find a control unit that can be fitted to your fridge. The original isn't available except from an old fridge.
You then have to get the old tube out and feed the new one into the back of the freezer compartment. It wasn't hard to replace just hard to find a control that works. Most will work if you make it fit.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
1966 vintage tire advice sought TheProfessor Tires 6 12-08-2009 09:57 PM
1966 17ft VINTAGE AIRSTREAM CARAVEL! eBay Watch Airstreams on eBay 0 09-19-2009 01:11 AM
1966 17ft VINTAGE AIRSTREAM CARAVEL eBay Watch Airstreams on eBay 0 09-01-2009 05:20 PM
Heat Element for Dometic M52 Fridge PeteL Refrigerators 1 04-22-2008 01:33 PM
Dometic M52 (67 Safari) gas flue baffle Joe Hege Refrigerators 4 08-23-2006 09:36 PM
