Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 02-28-2018, 07:15 PM   #1
Bexar's Avatar
1960 24' Tradewind
San Diego , California
Dometic M50 Thermocouple
On the road and the thermocouple on this M50 has failed. For those of you who did not give up on your M50, how have you handled replacing it with current off the shelf TCs?
This is a very good working and in good condition old fridge in my 60 Tradewind. I would like to figure this out. Al the threads I can find are old and just say replace it. I would prefer not.
Thanks! Richard
Bexar is offline   Reply With Quote
Old 03-02-2018, 10:36 AM   #2
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
send me a pic . I am looking for a click fast for a 76 in a 62 tradewind .
have it working with an electric element clamped to clickfast post and t-stat install inside ( out of rm 7030 ) customer would dearly love too get gas going again but won't mcgyver lpg ! have several old thermocouples so maybe . got a working clickfast ?
crestonrv is offline   Reply With Quote
Old 03-03-2018, 03:08 PM   #3
Bexar's Avatar
1960 24' Tradewind
Here is the thermocouple from the backside and the other end as it screws into the gas flow control. The threads, type & size of the opening is unknown and will hv to wait till I hv my full tool set at home but by the looks of it there are options for adaptations. I do not know if this is the stock thermocouple but the control valve looks original. Thanks for your help.
ID:	305407Click image for larger version
Old 03-03-2018, 05:42 PM   #4
2016 28' Flying Cloud
Defiance , Missouri
Good luck finding a thermocouple. I have an M50 in my 62 overlander, and converted it to 12v using a danfoss compressor, evaporator kit. It works great and I get to keep that beautiful vintage look.
62olander is offline   Reply With Quote
Old 03-03-2018, 05:47 PM   #5
Bexar's Avatar
1960 24' Tradewind
Can you tell me more abt your conversion? Tnx
Old 03-03-2018, 06:06 PM   #6
Defiance , Missouri
http://www.suremarineservice.com/ice-box-conversion-components.aspx
See link above for the kit I used, using a flat evaporator. The compressor fits under the fridge, install through the opening vent door. You will need to drill a 1” diameter hole to provide access for the cooling lines and thermostat wires.
It’s really pretty easy.
I’m out of town right now, I can send some photos in a week or so.
Old 03-03-2018, 07:30 PM   #7
Bexar's Avatar
1960 24' Tradewind
Sure like propane and do not carry enough battery to source the current needed for that dc conversion.
Old 03-03-2018, 07:35 PM   #8
Bexar's Avatar
1960 24' Tradewind
I have not dissected the existing thermocouple but since it’s not electrical it must be creating mechanical movement at the actuator end which controls gas flow. Is this right?
Old 03-04-2018, 07:10 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The thermocouple is an electrical device. It generates 20 milivolts which is needed to open the gas valve.
If the tube/piping is not compromised you may be able to disconnect it from the gas valve and clean the contact points. Both at the thermocouple tube end and inside the gas valve.
Be sure to push it in the gas valve when reinstalling. Do not over tighten it.
The flame end may need cleaning as well.
Be sure the flame end is located in the flame.
Old 03-04-2018, 04:54 PM   #10
Bexar's Avatar
1960 24' Tradewind
TG Twinkie this is good to know. I’m hopeful, when I get home in a few weeks I can disassemble the gas flow control and interface an off the shelf TC to it. Seems there are numerous TCs with a couple of wires coming off them.
Old 03-04-2018, 05:01 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Send me a pic of the back of the unit. There won't be any wires on the thermocouple. It will just be a small copper tube.
This type of thermocouple is used on household gas water heaters and are available at well stocked hardware stores.
Old 03-04-2018, 05:04 PM   #12
Bexar's Avatar
1960 24' Tradewind
I posted a pic of the back of the valve earlier in this thread.
Old 03-04-2018, 05:10 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Forgot you posted pics. In the top pic I can see flame so you have gas.
Are you travelling with the coach?
Old 03-04-2018, 05:13 PM   #14
Bexar's Avatar
1960 24' Tradewind
Yes to traveling with it and I hv the light button jammed to keep it lit. I’m the control for the interim. [emoji43]
Old 03-04-2018, 05:40 PM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
That is VERY dangerous!!! The gas valve will not close if the flame goes out.
Old 03-04-2018, 07:54 PM   #16
Bexar's Avatar
1960 24' Tradewind
Yes, I only light it if I’m in the coach and keeping an eye on it. It won’t do for unattended operation.
Old 03-25-2018, 08:46 PM   #17
Bexar's Avatar
1960 24' Tradewind
An update: the thermocouple once removed and tested put out well over the 10mv needed. But the end of the thermocouple going into the gas flow control was corroded. Once cleaned and reinstalled the good ol M50 fridge works perfectly.
Old 03-26-2018, 07:11 AM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Glad my suggestion of cleaning the contact points at the gas valve worked.
Makes me wonder how many refers were replaced because of this problem.
Travel Safe
Old 03-27-2018, 06:34 AM   #19
Bexar's Avatar
1960 24' Tradewind
Thanks for your suggestions too. They were helpful. Imo, even if the thermocouple goes bad, a new sensor, a modern exposed wire sensor can be spliced into the original thermocouple end which fits into the controller.
Additionally, like you, I feel there must be a compatible replacement otf. Now that I’ve seen this thermocouple and its connector I’m on the lookout. [emoji4] glad to hv this unit back as it wks well and fits this Tradewind in every respect.
Old 09-19-2018, 07:36 AM   #20
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
The link no longer works. I have researched electric conversions and see kits from Norcold, Nova Kool, Isotherm and others. Which did you use? Were you also able to keep a working freezer with the flat plate evaporator? I see some sell a box shaped evaporator that forms a new freezer, but I think you'd have to remove the original freezer to use them.
Photos would be appreciated.
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
M50 Fridge Venting 62olander Refrigerators 10 05-13-2015 07:53 AM
Nice original Pink Elephant Dometic M50 refrigerator. Works or for parts. shinyhome Airstream Classifieds 0 10-08-2014 10:49 AM
Thermocouple for Royal Dometic? MATTY J Refrigerators 12 01-31-2012 07:06 PM
Thermocouple for '68 Safari Dometic refer 26.982 amu Refrigerators 3 02-16-2009 08:29 AM
Dometic M50 wildcat455 Refrigerators 1 12-08-2003 07:48 PM
