Old 04-14-2007, 07:46 PM   #1
Devils Lake , North Dakota
Dometic Gas No Go
The fridge in my 73' will not stay running in gas.
I used a torch as the piezo is broken and although I could hear it running,
it would stop immediatly after I released the pilot knob. I held the knob in
for well over 5 minutes and the propane torch must have gotten the
thermocouple plenty warm.
I ran a seach with no luck and the manual is no help.
Works great on electric.
Sundance is offline   Reply With Quote
Old 04-14-2007, 08:54 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
sounds like your thermocoupler has failed
Old 04-14-2007, 09:38 PM   #3
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
mod # ? probably thermocouple,dometic specific part about 60.00 r&r t couple and on bench attach meter set to mil. volts heat end should read at least 30 mv if not replace. if replacement of t-couple still won't stay lit safety valve is bad.can be purchased as seperate part if local dealer with access to dometic direct is willing. first step before you take anything apart is to check lpg press with flame lit (hold button)10-12" water columne is apropriate. also clean burner and orfis may help.make sure t-couple is in flame.may have used t-couple e me if tou need it,don't sell used parts you pay freight.
crestonrv is offline   Reply With Quote
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
