Old 07-07-2010, 04:30 PM   #1
TorpedoFamily
Torpedo Family's Avatar
2005 30' Classic
Ozark , Alabama
Dometic Frig Help
My Frig is 4 degrees in freezer but will not get lower than 41 in frig part. What is wrong? Help
Torpedo Family is offline   Reply With Quote
Old 07-07-2010, 05:04 PM   #2
2008 16' Safari
Destrehan , Louisiana
Check the seals around the door.
dlb435 is offline   Reply With Quote
Old 07-07-2010, 05:43 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
What is the model number of your refer? Which Airstream is it in?
According to Dometic Spec, any fridge temp below 42* is within the design parameters. This might not be acceptable to you, but it is in their published specifications.
Let me know what your model # is and I can give you a few things to look at that might lower the fridge temps under 40*
Old 07-07-2010, 05:50 PM   #4
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Make sure your AS is perfectly level. Last week in the heat our frig wasn't quite as cold as normal. We were a little off level but not any more then when we had a MH with a Norcold frig. That was enough off level not let it cool down. Good luck, let us know what you find out. We will always be on the level now!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Help With Frig Airdaddy Refrigerators 1 07-07-2009 05:30 PM
WTB [1971 safari] dometic frig jamesardis Refrigerators 6 01-24-2008 04:12 PM
dometic rm2604 frig blows breaker 61landyacht 1960 - 1964 Overlander 2 05-19-2006 06:32 AM
Dometic Frig. Parts randallmiller Refrigerators 2 08-17-2004 07:43 PM
Dometic Frig seals replacements davidlaxson Refrigerators 3 12-08-2003 09:33 AM
