10-13-2018, 10:01 AM
2017 23' International
Austin
Dometic fridge only operating off L.P.
I have it on auto and it keeps clicking to try to use L.P. my rig is plugged in to shore power. I keep running out of L.P. because of this fridge.
Constant clicking and won’t operate off of shore power
The older I get , the better I was.
10-13-2018, 10:05 AM
2002 25' Safari
Dewey
Step 1 is to verify that the outlet that the fridge is plugged into has power.
Richard
10-13-2018, 10:18 AM
Austin
How would the light on the fridge operate and the display operate if it did not have power ?
Do I need to pull it out ?
10-13-2018, 10:29 AM
2002 25' Safari
Dewey
Most likely those lights are 12 volts. Refrigerators (current versions) have a 12 volt line that operates the circuit board. they are also plugged into a 120 volt outlet that supplies power to the heating element which heals the ammonia and produces the cold.
Your refrigerator is operating just like it would if you were not plugged into shore power. If it is running on propane it is either not connected to shore power, not sensing shore power or manually switched to gas mode. There should be a switch on the panel that will force it into gas mode, something else to check.
Richard
10-13-2018, 10:30 AM
2002 25' Safari
Dewey
You should be able to locate the power plug from the access door on the outside of your trailer behind the refrigerator.
Richard
10-13-2018, 10:52 AM
Austin
Power plug works
10-13-2018, 10:54 AM
Austin
I think it’s not sensing shore because the “auto” light it on
10-13-2018, 10:57 AM
2002 25' Safari
Dewey
The only other suggestion I have would be to reseat the connectors on the circuit board, but that is a long shot. If that does nopt correct the problem, it is time for a service call.
Did you verify that the unit was not switched to gas mode on the panel?
Richard
10-13-2018, 11:23 AM
Austin
It’s either on auto or it’s not , right ? It’s on auto. I even have the L.P. tanks disconnected now. It keeps trying to connect to them. Light the propane even though it’s on auto
10-13-2018, 12:26 PM
2002 25' Safari
Dewey
there are different versions, mine is either auto or gas. This gives you the ability to switch to gas mode if you have limited power. If you only had 3 amp power you would want to switch to gas mode.
In auto mode the fridge will run on electric if it is available and switch to gas if it is not. For some reason yours does not think electric is available. Possibly a bad circuit board.
Richard
10-13-2018, 01:06 PM
1994 34' Excella
Warren
, Manitoba
Did you confirm by plugging a trouble light or hair dryer into the 120volt outlet that the fridge is plugged into, that there is actually power to the outlet? Test the heating element in the fridge to make sure that it is not burnt out. All of the lights and controlls on the fridge are 12 volts. When on "auto" and 120 volts are available and working, your fridge will work on shore power as the prefered source of energy to cool the fridge.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
10-13-2018, 01:35 PM
Austin
Yes
10-13-2018, 02:05 PM
Austin
Originally Posted by CBWELL
Test the heating element in the fridge to make sure that it is not burnt out. .
How do we do that?
10-13-2018, 04:12 PM
1994 34' Excella
Warren
, Manitoba
The internet is your best friend. Type in "Dometic refridgerator repair heating element" and you will see a YouTube video on how to check/replace this part. Good luck, Chris
ACI #7394
1994 Excella 34'
Hensley Hitch
10-13-2018, 04:16 PM
Austin
It’s burnt thansk
10-14-2018, 10:33 AM
2018 25' Flying Cloud
Dallas
We experienced this same issue. On the first service visit they replaced a fuse in the frig. On the second service visit they replaced this circuit board. No issues since.
10-14-2018, 10:38 AM
2018 27' Flying Cloud
Naples
5 Amp Fuse Likely Culprit
I am having a similar issue with our 2018 27FB. I just saw a thread on the forum yesterday and the issue turned out to be a little 5 amp fuse in the refrigerator. The repair was accomplished by accessing the refrigerator from the outside of the trailer and then opening up a little box that had the fuses. Little GDC Series 5 Amp fuse. You can buy them at Home Depot or Lowes. They come in packs of 2 for about $5. The thread I found on the forum had pictures. Sorry new to the forum and not sure how to direct you back to that thread.
10-14-2018, 11:10 AM
2019 27' Globetrotter
WARRINGTON
, Pennsylvania
Hi Folks - we are on our first shakedown outing in our 2019 Globetrotter, and we have a similar issue - the refrigerator works on propane but not on electric. Where exactly can I find that fuse box to check the 5 amp fuse?
10-15-2018, 05:35 AM
Naples
If you access the back of the refrigerator from the exterior access panel on the outside of the trailer you should find a small box inside the equipment area. Inside that small box is GDC 5 Amp small fuses. Seems when these 5 Amp fuses are blown the fridge will only run off of LP.
10-15-2018, 02:23 PM
Airstream Ambassador
Jackson Center
, Ohio
Attachment 325079
Hi troubadour1,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
