Old 03-31-2016, 07:07 AM   #15
1996 25' Excella
Tillsonburg , Ontario
Jami20 Quote <After reconnecting everything I fired the fridge up and immediately noticed that the flames were all blue coming out of the burner tube. Before they had been more of an orange and yellow color. I also noticed the sound that was mentioned here as sounding kind of like a coffee pot. I stuck a half bottle of water in the freezer and came back three hours later to see ice in the bottle!> Quote
I would say the burner tube was the problem all along. You were getting a flame...poor one but a flame none-the-less. I have had to clean the burner on my '89 several times. Dirt and rust drop onto the slotted burner and clog it. Tube was nearly full first time I pulled it out. Congrats...you pulled the whole fridge...not many of us are quite that adventure-some.
JCW
JCWDCW is offline   Reply With Quote
Old 04-01-2016, 10:25 AM   #16
2006 28' International CCD
Germantown , Tennessee
Yeah, I don't know if I would haven taken the fridge out if I had not needed to do so in order to run wiring for the solar. I did it by myself and would not advise anyone to do that. It's not light and it would have been extremely helpful to have had a helper.
I also should say that it only took about 15 minutes to do, not including removing the fridge.
jami20 is offline   Reply With Quote
Old 05-04-2016, 07:43 AM   #17
1988 34.5' Airstream 345
Camarillo , California
Hello Everyone... My refrigerator pilot comes on and I can feel it heating the plate. and sensors on front know if AC is plugged in or if it is trying to cool with gas. BUT it never gets cool.
How do I check if I have refrigerant?
Does anyone have instructions as to how to replace the compressor?
Does anyone have the steps to pull the fridge?
I am guessing it is not just my flame, but another issue since not working on either source.
Ren
Ripley345 is offline   Reply With Quote
Old 05-04-2016, 08:08 AM   #18
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Dometic Fridge not running on Propane - Pulled it out and see this
There is no compressor in your refer. There is no refrigerant.
RV refers use and ammonia based system which is enclosed and heated with a burner (no pilot) or a electric heating element if on shore power.
If you don't see any yellow dust or smell ammonia the system may be OK.
There are a number of things that could cause problems. You may be able to find a PDF file (manual) on your specific model to help you analyze the problem(s).
It could be as simple as bad connection(s) on the control board.
Are you sure you have 12 volts DC at the refer?
Old 05-04-2016, 09:03 AM   #19
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Yep, the dreaded yellow dust signaled the end of our Dometic from 1999. Replaced with a NorCold and very very happy.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 20 04-12-2017 01:31 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 08:56 AM
Dometic Fridge not lighting w/Propane zimode Refrigerators 9 09-21-2009 07:08 AM
