Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 04-27-2008, 03:36 PM   #1
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
Dometic fridge mystery shield
ok, so it may just be a mystery to me but.......
this sheild is just hanging out on the floor. where should it be? i didn't want to just stick it somewhere to try it and short something out. does anyone have a picture as to where and positioning?
thanks again
Name:	fridge shield.JPG
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Old 04-27-2008, 05:25 PM   #2
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
Since my experience is with a way older Dometic, I'm not really sure. But could it be some type of dislodged baffle to shield the burner from draft?
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, WDCU & 4CU
Sugarfoot is offline   Reply With Quote
Old 04-27-2008, 05:56 PM   #3
Profile:  Corona , California
That's what it is.
A baffle so that the wind sitting still or traveling, will not blow out the burner flame.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 04-27-2008, 06:13 PM   #4
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Everyone's correct!
The shield should be in place.......not sitting idly on the compartment floor. The curved area goes up against the boiler tube the long vertical section right above the LP burner (usually wedging right underneath it), with the boxed section shielding the air intake and LP supply tube.
There should be at least one screw hole in it to hold it in place.
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 04-27-2008, 06:29 PM   #5
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Ours had two, plus a slot for another piece of another shield to slide into.
(No Longer at Inland RV)
Old 04-27-2008, 08:11 PM   #6
richinny's Avatar
so, i've got a screw or two loose? lol
thanks again everyone! i figured the curve in the shield indicated it should go somewhere next to the tube. and also, when i took a close look at the 3 pictures i have, one shows a screw sitting in there too!
i'll put it on the list for the reunion ib December :-)
Ricky
Dometic fridge davidz71 Refrigerators 1 04-13-2008 07:23 PM
1962 dometic fridge tobynamy Refrigerators 2 06-21-2006 07:53 PM
Dometic Fridge I think--need help calredcoat Refrigerators 3 05-30-2006 06:54 PM
68 Dometic Fridge bmongiello Refrigerators 3 05-30-2006 12:31 PM
Dometic Fridge angie@smartw Refrigerators 3 08-03-2005 09:57 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
