Old 05-30-2006, 05:33 PM   #1
1964 26' Overlander
Spring , Texas
Images: 12
Dometic Fridge I think--need help
Hi, Still new to this site but, totally love all the feed back. We just purchased a 1964 Overlander. We have no info or history on this unit. I believe we have a Dometic fridge. The only number I can find says unit type
510A. I believe it is both gas and electric. Can anyone help with info. My husband changed out the electrical cord and plugged it in. Nothing appears to be happening. Not sure how it operates and looking for some direction. It may just be gone. Thanks
Name:	inside of frdge.jpg
Name:	Back of fridge.jpg
calredcoat is offline   Reply With Quote
Old 05-30-2006, 05:46 PM   #2
I had a pink one just like it with the rust and all I pulled out of my 61' ! I put it on Craigslist for free and it was gone 15 minutes after I posted it. I talked a service guy at an AS dealer who owns several AS's and he told me to toss mine. I guess they can be quite a fire hazard if not working correctly.
1961 Overlander
Englewood, Colorado
Todd@SparksRealEstateGroup.com
sparks is offline   Reply With Quote
Old 05-30-2006, 06:47 PM   #3
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Calredcoat
If you're not used to RV type fridges they can fool you.
They don't hum or run or buzz like the fridge in the house.
It's all a rather mysterious system of heat causing the gas in the coil to expand and pass through a restricted oriface which causes the cooling to occur. Not that I understand any of it...
But it won't make ANY noise. Let it set plugged in for a few hours then check the freezer. Hopefully you will be rewarded for your patience.
Also, make sure the fridge is level. I thought mine was on the blink because it stopped cooling. Turned out that when I moved the tailer a few feet to mow around it I hadn't remembered to re level the trailer.
I have had a couple of old Dometics in other campers and my experience is that they are quirky but very reliable.
Good luck
Jerry
Ultradog is offline   Reply With Quote
Old 05-30-2006, 06:54 PM   #4
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Some of these units must have a 12 volt supply for instrumentation as well as the 110 ac. The same goes for the ac unit. Best of luck
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
