Old 11-11-2005, 08:58 PM   #1
Arnold , Missouri
Exclamation Dometic fridge doors
Does anybody close to St. Louis have a Dometic for parts? I need doors for a model #3862 as the hinges are about break on mine.
Thanks!
sportfury65
sportfury65 is offline   Reply With Quote
Old 11-12-2005, 08:29 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings sprotfury65!
Welcome to the Forums!
Thanks!
sportfury65
A possible source not too far from your greater St. Louis location might be Colaws RV Salvage in Carthage, MO. You can find their website at:
http://www.colawrvsalvage.com/
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 11-25-2005, 01:37 PM   #3
JimGolden's Avatar
1977 31' Excella 500
Off the topic, but do you have a '65 Plymouth SportFury?
I've got one. Had it for 21 years. Was my first car, got it when I was 15. Blew off the junior prom to work on the Plymouth in the bodyshop. Fixed it up once, drove it for awhile. Parked it when I went to college. Started to fix it up a second time but never finished it. The car is still solid. I replaced the drum brakes with spindles from a '69 New Yorker and the power disk brakes from the same car. Also swapped in the heavier rear out of the New Yorker with the bigger drum brakes. Rebuilt the engine from the New Yorker too. One of these years I'll get around to finishing the car up. Got a rebuilt 440 (now a 447) on the engine stand ready to go for it, along with an A833 4-speed. Did it right, Mopar Performance intake, ported and polished heads, TRW forged pistons, Purple Shaft cam, should make about 450hp.
Got married and built a house...not much time for hot rods anymore. Still have my old Plymmy though
Good luck with your fridge,
JimGolden is offline   Reply With Quote
1977 Dometic refridgerator overlander Refrigerators 30 03-14-2015 01:08 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 04:36 AM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 07:34 PM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 09:34 AM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 08:22 PM
