Old 11-14-2010, 12:49 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Dometic fridge belly up.
Our fairly fresh (8-03) #RM-2820 "Classic" has quit cooling on ac/propane. I shut it down, checked for level (not too important on the newer ones), let it defrost and sit for 24 hours with the doors open. Went to re-fire on 115 and, while sitting outside next to the door, suddenly smelled ammonia with a hissing sound like the propane was on. Shut it down, pulled/shut-off the ac and propane. Smell and hissing quit after a few minutes. Question is, what should I advise the mechanics to have ready to fix this problem? I don't relish sitting on the hook while parts are ordered, since we'll have to go to Oasis in Tucson for service and we're in Ajo. Thanks for any input.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-14-2010, 01:20 PM   #2
SteveH's Avatar
Common Sense , Texas
I've not had one fail, but from what friends have told me that have, you either replace the cooling unit, or the entire refrigirator.
I'm sure when you tell Oasis what happened, they will know what to do.
Regards,
Steve
Old 11-14-2010, 01:37 PM   #3
Mike Leary's Avatar
Images: 11
I agree, labor to repair could be more or as much as a fresh fridge. Oasis has a good reputation, I'll call them tomorrow.
Old 11-14-2010, 02:02 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
Mine . . .
Currently residing in a pre-trash staging area.
Gary
Old 11-14-2010, 02:14 PM   #5
Mike Leary's Avatar
Images: 11
Understood, I had our previous original fridge "re-built" because of the same smell I'm having: lasted a year, if that.
Old 11-14-2010, 03:52 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Mike,
The original fridge in my 1983 Excella quit cooling a couple of years ago. I decided to replace it even though I didn't have as exciting a failure as yours. Even when mine was working, the old seals didn't really keep the cold in.
The new fridge ranks right up with the new AC for the best improvements to my 1983.
Vaughan
Old 11-14-2010, 04:35 PM   #7
Mike Leary's Avatar
Images: 11
I'm still on the fence. A fresh Dometic runs around $1300+ plus labor. I'm hoping ours is new enough to be re-built, but looking at all the tubes connected to the cooling unit and the associated labor to re-do, plus either staying in Tucson or coming back from Ajo, I'm not sure. I'm not going anywhere until either parts or a fresh fridge are available. We're lucky to have a friend who has a (kinda sorta) fridge available for us, but our smoked salmon from the PNW is looking rather thawed.
Old 11-21-2010, 10:15 AM   #8
nipigon , Ontario
Check and see if there is a recall for your unit, just a though?
mexifin is offline   Reply With Quote
Old 11-21-2010, 12:36 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Mike,
The general 'fix' for your depleted cooling unit (it has failed and there is a hole in the tubing that has let the coolant, a mix of ammonia, water, hydrogen gas and sodium chromate, totally escape) is to remove your bad cooling unit and replace it with a new one.
If you chose to have this done, I would specify that you want an original Dometic cooling unit, as I have seen that the off-brands which are cheaper never perform as well or last as long as the original. Plus, they are always very hard to get any type of warranty service from, unlike Dometic which will stand behind their warranty.
PS: if your unit was part of the Dometic recall, they will not replace the cooling unit, as the recall had to do with adding a thermal sensor to your unit that shuts down the unit in the event of a fire of over-temp situation.
Old 11-21-2010, 01:50 PM   #10
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
PPL here in Houston has pretty good prices on Dometic, bought a replacement unit for my 72 Tradewind and they were cheaper than others and have a lot in stock.
RichHog is offline   Reply With Quote
? on dometic fridge twiggy137 Refrigerators 11 05-23-2008 05:58 AM
Dometic fridge davidz71 Refrigerators 1 04-13-2008 07:23 PM
Dometic Fridge I think--need help calredcoat Refrigerators 3 05-30-2006 06:54 PM
68 Dometic Fridge bmongiello Refrigerators 3 05-30-2006 12:31 PM
Dometic Fridge angie@smartw Refrigerators 3 08-03-2005 09:57 AM
