Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 08-03-2005, 08:04 AM   #1
angie@smartw
Profile:
Dometic Fridge
just pulled our first airstream home. A 25 ft 89 excella. Fridge was replaced in 98. Its works great when we pluged in to power, but during the ride home it did not work off the LP. We also had two tires blow, and had to jack it up so I am wondering if something happened when we raised the airstream.
Also the little pin that hold the handle on the fridge clasp is missing- any help would be great.
angie@smartw is offline   Reply With Quote
Old 08-03-2005, 08:26 AM   #2
sovereignrwe
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
First...Congratulations on your new Airstream! Our second trailer will be around the size of yours.
Second...Where did you put the jack? Proper placement is between the wheels.
Third...Do you know that the Fridge worked on LP before you left the Previous Owner (PO)?
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-03-2005, 08:56 AM   #3
angie@smartw
Profile:
Hi-
The jack was put in many places, as we ended up having to replace all tires.
I looked under there, it looks fine, but maybe soemthing happened inside.
The firdge did work on Lp the day before. it seemed to take a lon time to get cold, but it did work.
Many thanks in advance.
Angie
Angie@smartwired.org
Park City, Utah
Old 08-03-2005, 09:57 AM   #4
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Check the burner. It is probably dirty. If the fridge works well on electric but not well on gas, that's a likely cause. You should have the refrigerator professionally serviced -- a faulty gas fridge can cost you an entire Airstream!
WBCCI #9990 | VAC | Full-timer | AIRSTREAM LIFE magazine | Tour of America weblog
rluhr is offline   Reply With Quote
removing Dometic Refrigerator smily Refrigerators 14 10-29-2007 04:01 PM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
1977 dometic refridgerator overlander Refrigerators 29 10-07-2002 07:11 PM
Propane fridge installation yaakman Refrigerators 5 09-12-2002 06:34 PM
Repairing cracks in fridge plastic? Charcigar Refrigerators 2 05-01-2002 06:44 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
