Old 11-27-2006, 05:56 PM   #1
Naturescalin's Avatar
1983 31' Excella
Bellevue , Washington
Dometic freezing main compartment
My refer unit is breaking barley refreshment bottles and other valuables. It was all frosted up so I defrosted it. Now the bird is all frozen from Thursday. Where will it all end? What can I replace prior to the unit? It is relatively new.
Cold and getting colder in Seattle.
Naturescalin is offline   Reply With Quote
Old 11-27-2006, 06:11 PM   #2
The thermostat or thermocouple is shot or disconnected.
When one of them go, they source of heat, which causes the cooling stays wide open, telling the system to get even colder.
Old 11-30-2006, 07:36 PM   #3
1983 31' Excella
In the Americana where do I find it to replace it?
Old 01-18-2007, 10:35 AM   #4
tyndalelady's Avatar
Prescott Valley , Arizona
Bump.
Is it an easy replacement?
1983 Excella 31 - Sold
2001 Dodge 2500 V10 - Sold
Looking for a new rig and tow vehicle.
tyndalelady is offline   Reply With Quote
Old 01-18-2007, 10:52 AM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Hi Guys- Been there done that! Last year while traveling cross country we ran into the exact same problem. Everything was frozen. It was the first week into a three 1/2 week trip. We ended up turning the unit off during the days and on at night and that kept everthing pretty stable. We first noticed the freezing when I went to make eggs early one morning and they wouldn't crack open and then upon closer examination, the were pre-cracked but solid! On the last part of the trip we stopped at JC to say hello to friends and have the axels alligned. They immediatly started testing the ref. for us and first replaced the whole board, then replaced the coupler which was the actual cause of the freeze. Simple to do on your own but we were still under warranty. I would first unhook the coupler and reattach, if that doesn't work replace it. If that doesn't work change out the board and you will be all set.
Let us know how you make out!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-18-2007, 01:22 PM   #6
east stroudsburg , Pennsylvania
replace the temp probe, located on the fins on the rear of the refer compartment, usually cliped on, white in color. If that does'nt work you have to replace the control board.
RV_cool is offline   Reply With Quote
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
