Old 04-03-2011, 06:50 PM   #1
1973 23' Safari
Bible Hill , Nova Scotia
Dometic freezer door springs
I took the freezer door out of my RM 60a (single door) in order to take it apart and install a new door seal. Mission accomplished, except now HOW do I rewind the 2 door springs while getting the freezer door back in?
A few - or more than a few - must have done this....
Thanks in advance.
George
SafariGeorge is offline   Reply With Quote
Old 06-25-2011, 01:18 PM   #2
1996 21' Sovereign
Morro Bay , California
Hi George....we are in a similar situation...took freezer door off the refigerator in a 1979 Argosy to put new seal on and I broke the right insert...sooooo, for several weeks we have been trying to get a replacement part and it should be here on Mon....so after we try to put it back together, will let you know if we solve the rewind spring problem. How close are you to Dartmouth? My mom's family lives there...just love to visit...Thanks, bonnievast@gmail.com
bonnievast is offline   Reply With Quote
Old 06-30-2011, 06:35 PM   #3
1996 21' Sovereign
hi George... we did get the freezer door back on and you do have to rewind the springs...if it is still a problem for you, let me know and i will try to e-mail an answer for you
Old 06-30-2011, 07:59 PM   #4
1979 Argosy Minuet 7.3 Metre
grand rapids , Michigan
were do you get the spring and the gasket for the refridge? I have a 79 argosy.
bobberfrog is offline   Reply With Quote
Old 07-01-2011, 05:37 AM   #5
1973 23' Safari
Would like to know.
Hi Bonnie - yes please I would like to know how you rewound the springs..... bobberfrog, the gaskets came from All Seasons RV Appliance Parts & Service, Elkhart, IN 800-344-0673 All Seasons RV Appliance Parts & Service
Old 07-01-2011, 09:44 AM   #6
1996 21' Sovereign
hi...we purchased ours from PPL motors in Texas #713-988-5555...it took forever to get all the parts...I think they order them from another place..so will keep your resource for future use...
.I am typing this as per my husband's instructions...GOOD LUCK......."I removed the hinge from the right bottom of the freezer door by taking out the 2 bottom screws, leaving the right side spring assembly out...I then put left side spring assembly into the well leaving spring assembly with handle part pointed at me..I then placed door on assembly in vertical position.I then used a screwdriver and pushed clip up until tab locked while still holding door. Holding the door up, I placed the right side spring assembly into the well. I then twisted the door hinge about 1/2 turn to load the spring.....I then put the screws in.....
Dometic Penguin or Coleman Polar Cub for 1967 Caravel?? vonzellen Furnaces, Heaters, Fireplaces & Air Conditioning 20 08-13-2011 06:10 AM
Repair to Interior Door Panels of Dometic M 70b 69 AirDream Refrigerators 13 04-01-2011 07:15 AM
Wire question - Dometic Americana RM2552 adwriter73 Refrigerators 3 03-23-2011 01:11 PM
Dometic Inverter Generator nm1oqrz Generators & Solar Power 2 02-27-2011 08:12 AM
RM 2410 and 2510 Freezer Door Widths pbearsailor Refrigerators 4 01-07-2011 07:16 PM
