I have a 1976 Argosy 24 that has a Dometic RM77D 2 door frig. The frig works fine but the bottom of the door has swelled and will not close. Has anyone run into this problem and is there a fix? I cannot find a replacement door anywhere.
I had that problem on a 69.. It seems the foam insulation in the door swells over time and pushes out the plastic inner door. It can be enough to break it. I removed the inner panel and used a wood rasp to remove a little bit of the foam and then re assembled the door and it seemed to take care of it.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
