Old 07-24-2004, 12:11 PM   #1
rochar3's Avatar
2003 31' Classic
Valparaiso , Indiana
Dometic door fell off
Help!
My dometic refrigerator door fell off. Seems that the Cheap plastic piece on the fridge door that holds the hinge pin broke off. I repaired same and now I don't know how to fit the door back on. It looks like I will have to remove the complete unit to put the door back on. This doesn't seem right and I am wondering if anybody out there can help.
Bob Adney
rochar3 is offline   Reply With Quote
Old 07-24-2004, 12:17 PM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
bob
the pins are threaded, back them off a bit and you can set the door back in place.
make sure the latch is centered or it will fall off again! you can do this by adding washers to the bottom pin until the door is centered on the latch.
john
you call them ferrets, i call them weasels.
1977 Dometic refridgerator overlander Refrigerators 30 03-14-2015 12:08 PM
Two Door Dometic Refrigerators Models, Parts, Data jaco Refrigerators 10 07-25-2009 04:12 PM
Dometic Fridge door. Antique Pedaler Refrigerators 3 08-04-2008 11:32 PM
Dometic RM100 TGB96 Refrigerators 9 08-30-2004 12:38 PM
Need Dometic RM2201 fridge 85MH325 Refrigerators 0 07-24-2004 09:13 AM
