Old 07-27-2011, 09:34 PM   #1
x
XXXX , XXXX
Dometic Cooling Unit Failures
I have noticed that on several of the dometic fridges that have had the safety recall retrofit done to them the cooling units are failing. They seem to operate for about a year after the recall was performed. They all have failed in the same spot right at the base of the unit where the propane flame is. So far the failure rate here is four in about twenty fridges that have had the recall retrofit installed.
Of course these fridges are out of warranty and were working fine before the recall.
I am wondering if there is any corelation to the failure with the retrofit.
A safety sheild is being installed in front of the burner and I suspect that it is restricting the input of fresh air to the chimney and the units are overheating causing the failure to the cooling unit.
Has anyone else had this happen to them? If so post your experience and if Dometic was called and if they did anything about it.
I wonder if it's time to get a class action suit going?
wasagachris is offline   Reply With Quote
Old 07-28-2011, 06:45 AM   #2
dznf0g's Avatar
Oswego , Illinois
That's where mine failed this spring. PO had recall done. I would think if there was an airflow problem, the flame would be yellow and sputtering. At night you can see the reflection of a hard blue flame behind the shield.
Over the years, I have had 3 dometic failures, all in the same area (rusty at the base of the chimney area). I believe they just use very poor coatings on the cooling units. It appears to be a primer of some sort. I'm sure it burns off in that area and allows corrosion. Either way, it's not durable and is poor quality.
That being said, my first one, in a 1972 Venture pop-up, was still working when I sold it 22 years later. BUT...it was always kept in a climate controlled garage, where humidity could'nt get to it.
I called Dometic several years ago, when my SOB fridge failed after only 5 years and they were NOT helpful. After "discussing" it with several reps, I got a Manager, who only would offer a free extended warranty on a new unit. He completely missed the point that I SHOULDN'T NEED an extended warranty, if the product was durable.
This is not news to them, and they keep building them the same way for decades. I didn't even bother to call them this time. Got a new cooling unit from RVcooling units.com.
Old 08-30-2011, 07:51 AM   #3
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
I have a '69 International 27' with a Dometic frig from a '73 model year. I am looking to replace the frig or install a new cooling coil. I need a source for the coils. Thanks for any help.
Hugheym
hugheym is offline   Reply With Quote
Old 08-30-2011, 08:11 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Had the recall done two years ago at AS of Western PA, SFSG. (quality service at that Store) No sign of excessive rust yet, but a pre-emptive strike may be warranted.
Dometic quality...not so much.
JC replaced the original Dometic in our 63 after 30yrs, it failed after 5.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 08-30-2011, 10:20 AM   #5
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Mine failed about 2 years after the recall. Same thing, ammonia leak near the bottom of the boiler. Flame was nice and blue, though, and there was no soot which would mean it was clean burning.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 08-30-2011, 01:31 PM   #6
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Our Dometic went "ammonia" after eight years. Not bad, considering we full time.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-30-2011, 03:36 PM   #7
dznf0g's Avatar
Oswego , Illinois
Actually, Mike, it is my belief that they last longer the more they are used. I think the corrosion at the chimney base is accellerated when there is no heat to drive the moisture away from the boiler/insulation area.
Old 08-30-2011, 05:08 PM   #8
Mike Leary's Avatar
Images: 11
That has been my experience: boats and coaches don't get any better sitting on "the hard".
RV Cooling Unit Warehouse dznf0g Refrigerators 5 08-07-2013 06:24 AM
Parting our Dometic RM 75D refer. buffaloman Refrigerators 0 07-07-2011 09:35 PM
2010 Dometic A/C hansenk Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-04-2011 08:33 PM
Adding an AC Unit Alamo Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-10-2011 07:51 PM
NM Unit and 4CU Jemez Mountains Joint Rally LHall WBCCI Rallies & Events 0 01-05-2011 07:27 PM
