Old 07-22-2009, 05:19 PM   #1
Ben4762's Avatar
1989 32' Excella
Lawrenceville , Georgia
Dometic Classic RM2820
I installed this fridge in July '05. For the second time the door latch spring has broken and the door opened while traveling. Food fell out onto the floor. Does anyone have a permanent fix for the latch?
Ben4762 is offline   Reply With Quote
Old 06-30-2013, 04:40 PM   #2
1994 30' Excella
Vail , Arizona
Just replace the spring...
A little late to this party, but FYI... the latch's pivot pin punches out easily, and then you can just replace the spring (using the spring in the other still-working latch to do the hardware store search... like the biggest Ace Hardware in your area). I'll do that search tomorrow and update here. Note: take pics of the 'good' latch as you disassemble, so you remember how the latch goes back together.
pappyrsg is offline   Reply With Quote
Old 07-02-2013, 03:18 PM   #3
1994 30' Excella
Vail , Arizona
Latch problem solved, or "Hey Dometic, I got your $35 right here!"
Found a replacement spring, much better than the original, and cheap. Tried the hardware store search... not very fruitful in these days of inventory defined by fast turn sales. Did get some suggestions though, that eventually led to a solution... first looked at mouse traps (springs too big), then clothes pins (still too big), then thought of those little potato chip bag closure clips... just right, and much stronger than the original cheap China crap spring Dometic used. See my attached.
You probably already have some of these clips (of the smaller variety), but they're available at any dollar store and most grocery stores. Also cheap China crap, but the springs are a better quality and much stronger than those used by Dometic in their $35 latches... imagine that.
- Pic 1: starting point.. latch, broken spring, good spring, chip bag clip
- Pic 2: old weak-kneed good spring, new spring from chip clip
- Pic 3: trimming new spring down to fit in latch
- Pic 4: same as Pic 2 but new spring trimmed down
- Pic 5: new spring sitting in one half of latch, ready to assemble
- Pic 6: latch assembled
Getting from Pic 5 to 6 takes some labor and care, maneuvering the new spring into both halves of the latch, slipping latch pivot pin through the new spring and then through the other end of the inside latch half (use a very small screwdriver to coax it, but watch out not to stress Dometic's cheap plastic latch... could break), and be sure to get the pivot pin's large end into the tighter end of the outside latch half. You also may need to 'adjust' (bend) your latch strike plate on the frig so the plastic door latch engages just right... to avoid the stronger-sprung latch from breaking when it hits a mis-aligned strike plate. A little work beats adding $35 to $40 to Dometic's revenue stream.
Name:	2013-07-02 13.16.11.jpg
ID:	189993   Click image for larger version
Name:	2013-07-02 13.17.19.jpg
Name:	2013-07-02 13.18.14.jpg
ID:	189995   Click image for larger version
Name:	2013-07-02 13.19.46.jpg
Name:	2013-07-02 13.23.14.jpg
ID:	189997   Click image for larger version
Name:	2013-07-02 13.26.27.jpg
Classic or Classic Limited? Bluto 2006 - 2010 Classic (all lengths) 8 03-23-2009 09:10 PM
- Classic FB 27' or Classic 30' Sky Community Polls 2 05-11-2007 02:34 PM
New Dometic or Not?? sequoiacoast Refrigerators 24 02-16-2006 08:51 PM
Classic 25A / Classic 25B DreamStream 2001 - 2005 Classic 8 04-27-2004 05:19 PM
Dometic Refrigerator scotta Airstream Motorhome Forums 1 03-16-2003 09:57 AM
