Old 06-13-2010, 01:35 PM   #1
tdveal's Avatar
1972 29' Ambassador
Sherwood , Oregon
Dometic 75A Refridge - Bad Electrical Element - 2nd Occcurence
Hello Fellow Travelers- I just replaced the heating element a few months ago and it has failed again. Looking for info that might suggest causes. Hopefully it was just a faulty element. I typically keep it hooked up even when not in use.
Both failures had the same symptom which was the wire at the top of the element had corroded..
tdveal is offline   Reply With Quote
heating element, dometic
Heating element in Dometic fridge Ultradog Refrigerators 7 03-11-2015 12:49 PM
hot wire dometic heating element johnfarrow Refrigerators 2 05-18-2010 06:14 PM
Dometic RM 75a... hot/ground reverse jayhudd Refrigerators 0 01-22-2010 03:38 PM
Dometic RM 75A - Need burner housing and plate. Zac A Taylor Refrigerators 0 09-02-2008 11:38 PM
Heat Element for Dometic M52 Fridge PeteL Refrigerators 1 04-22-2008 01:33 PM
