Old 06-16-2007, 04:43 PM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
Dometic 75 - RM77 : Problem with how to...
Hi.
I think I have to face a problem with my fridge.
Today it doesn't seem to work on electric.
It was fine till this afternoon. It was pretty warm outside, around 86F and when it was time to open it for a good beer it was not too cold inside...
I put it on gas, so I am waiting to see if it's ok now.
But so far from what I checked when it was on 110v the heater seemed to stay cold. So to me it doesn't work. But is it the heater or is it the thermostat that doesn't call for cold.
How can I figure that out?
How hard is it to find a thermostat on such an old unit or a heater...
thank you for your help
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 06-16-2007, 08:02 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Dufferin,
It's easy to see if your AC element is operating. You have to isolate it from the fridge's system.
1. locate the element in the boiler section of the fridge. It is a 1/2" or so L-shaped rod with the long section buried in the boiler and the short section visible.
2. locate the 2 wires coming from the element and follow them to the control box.
3. remove the wires from the control box.
4. make a pigtail (usually with 2- 1/4" male spade connectors) with an old extension cord (2-wire is fine). Attach the connectors to the cord. Polarity does not matter here.
5. plug in your extension pigtail to a known working 120VAC outlet. Let the fridge run overnight.
If your element is OK, the box will be VERY cold when you open it.
You can also do a continuity check of the element, but Dometic prefers to do the above procedure as a fool-proof verification.
Good luck and be sure to report back with your results.
Old 06-16-2007, 09:01 PM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Da google be your friend!
Service manual
http://gasrefrigeration.net/dom_techdata/24_77SM.PDF
Dometic refrigerators - Download Dometic Manuals
The general service manual on the list on the bottom left is a good read.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 06-17-2007, 10:38 AM   #4
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Thank you for those advices.
Lewster easy way to check... do that tonight...
then if one the part is gone I know where to find another one.
TAC# : QC-1
my blog
Old 07-15-2007, 09:39 AM   #5
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
small update.
The heater element is gone.
to be replace..
thanks for the help.
TAC# : QC-1
my blog
Old 07-16-2007, 12:11 AM   #6
lewster's Avatar
Originally Posted by dufferin
small update.
to be replace..
See................told ya' so!
Glad you found the trouble.....................................
Old 07-02-2013, 09:47 AM   #7
Tdcraw's Avatar
Yukon , Oklahoma
Did the test and failed. I followed the service manual, bent the pin and when I went to pull the top just fell a part. How do I get it instock and out to put a new one in?
Tdcraw is offline   Reply With Quote
Old 07-02-2013, 10:30 AM   #8
lewster's Avatar
Open up the insulation wrap around the old tube that holds your AC heating element. If you're lucky.....there just might be another tube sitting right next to that one.....EMPTY!
Some cooling units were made to accept 3-way operation, but many were only used in LP/120VAC operation. This extra heating element tube is for the 12VDC heating element, which you should not have present in a 2-way unit.
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
Low Voltage Problem kellyw Electrical - Systems, Generators, Batteries & Solar 3 10-23-2002 06:35 PM
Opps... (Split thread problem) Andy R Our Community 1 10-19-2002 02:12 AM
refrig cooling problem frydmans 1969 - 1973 Safari 12 08-25-2002 06:19 PM
Dometic Furnance Help chrisg Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
