Old 07-31-2013, 10:15 PM   #1
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
I have a four year old Dometic 3762 that is acting up. When plugged into 110v, the freezer and refrigerator compartments cool normally. When operating on LP only, the freezer compartment cools normally, but the refrigerator compartment stays warm. Talked to both Dometic customer service, and Airstream technical support, and no one was able to help.
So far I have replaced the main propane regulator and the hoses to both bottles, and removed, cleaned and re-installed the burner tube.
Airstream 65 is offline   Reply With Quote
Old 08-07-2013, 04:12 PM   #2
Mossiyjack's Avatar
1973 31' Sovereign
Cornville , Arizona
I have a similar condition in my '73. However my freezer compartment works fine on electric but the lower will not get below 50 degrees. I have yet to try it on gas because I have the propane system partially disassembled.
Mossiyjack@gmail.com
Mossiyjack is offline   Reply With Quote
